magicman wrote:It would be.
Thanks for the help.
DeanG wrote:Does anyone have contact information to order a Samco Federal hose set?
dapinky wrote:There's obviously a glut of these things going wrong at the moment - see this thread from Joao....
I think that during all of the discussion there, that it is the short bit that you need (or that is what I've seen on all SE's, but can't comment on the S2) - that was what Joao needed.
It is a reasonable price from SJs. but if it's only for a short time and you want to risk a S/H one, I can send you the one I dug out for Joao (he went for a new one).
AFAIK it is in good nick (wasn't leaking when i swapped it for the Samcos).
If, for any reason yours (being an S2) is the longer version, then I can throw the other pipe and connector to make up the longer bit into the same parcel for you.
Unfortunately, I can't help with the heater valve 'cos he did have my spare one off me!!!!
Fredjohn wrote:Following picture is from parts manual
Is it Item 1? In which case it is Lotus Part no: C100K0026F for the turbo model. Available from SJ Sports Cars for a mere £86.73 +VAT+carriage.![]()
Or item 2 B100K0029F for n/a same source £6.63 plus plus
Or you can do as Pete suggests, buy a bit of copper pipe and some jubilee clips.
magicman wrote:Thanks for all the help. I have ordered the single pipe from Paul Matty, as I guess if the 1st one lasted 20 years then the next should too.
