Share your pictures!
by muley » Mon 22.11.2010, 12:24
is the second one a spacer from the front upper wishbone?
by Specky » Mon 22.11.2010, 14:10
Is the second one a chassis to tub rear spacer...
by ashm » Mon 22.11.2010, 16:23
muley: nope
Specky: nope, but warmer!
Ad
ashm
by Monty » Mon 22.11.2010, 21:14
1st pic, a clip for a vaccum hose
the 2nd pic, is it a spacer for packing out one of thr hood seal
- Chunder King!
by steve matthews » Mon 22.11.2010, 23:30
Does the first live near the gas tank?
The second door hinge spacer.
Steve
steve matthews
by ashm » Tue 23.11.2010, 11:31
Hmm... I thought the first one would be easy! You'll kick yourself...
As for the second one: you're right in thinking it's a shim, but for where?
Adam
ashm
by Monty » Tue 23.11.2010, 18:06
is the 1st pic the clip for the accelerator cable?
and is that shim made of metal?
- Chunder King!
by inkitin » Tue 23.11.2010, 20:02
Is the second one the steel plate at the bottom of the A-Panel fixing?
If it is, it's somewhat shinier than mine are !
91 SE Calypso Red
inkitin
by whippit » Tue 23.11.2010, 23:35
second one front bumper shim, me think,
whippit
by ashm » Wed 24.11.2010, 13:19
The second one's made of plastic. And it's 1.6mm thick, apparently.
If you can guess one of them I'm happy to tell you what the other one is - feels like I underestimated the difficulty somewhat!
Adam
ashm
by Specky » Wed 24.11.2010, 21:12
I owe you all an apology
the heater switch wasn't off the M200 as well, I've just found my M200 pics....
Sorry about the lines, but I had to protect the picture a bit.
Bugger...
by Andy_J » Wed 24.11.2010, 22:13
Heather switch is off an LC
90H BRG SE 48,000 Miles
Andy_J
by ashm » Wed 01.12.2010, 01:46
Ok, I appear to have killed the thread!
So to give it a nudge, #2 is an A-panel mounting shim (A100B2509K)
and if you raise the bonnet and stand in front of the car you should (probably) be able to see part of #1.
Adam
ashm
by Specky » Wed 01.12.2010, 09:04
I'd like to see you raise the bonnet and not stand in front of the car...
by inkitin » Wed 01.12.2010, 20:09
inkitin wrote:Is the second one the steel plate at the bottom of the A-Panel fixing?
ashm wrote:So to give it a nudge, #2 is an A-panel mounting shim (A100B2509K)
Adam
91 SE Calypso Red
inkitin
by Dave Eds » Wed 01.12.2010, 20:58
I did wonder Roland
Crack on then mate
by steve matthews » Wed 01.12.2010, 23:12
Sorry can't find it on my Fed car.
Steve
steve matthews
by ashm » Thu 02.12.2010, 15:25
inkitin wrote:inkitin wrote:Is the second one the steel plate at the bottom of the A-Panel fixing?
Adam
Close, but not quite!
Apparently the steel plate at the bottom is B100B1262F.
The part in the photo is a plastic shim and goes at the top of the A-panel, as below:
However, the parts guide and the service manual seem to show different things, and neither quite matches up with my car... Anyway, you were closer than anybody else!
Adam
ashm
Return to Picture Gallery
