What's this...
Share your pictures!
Re: What's this...
Postby muley » Mon 22.11.2010, 12:24
is the second one a spacer from the front upper wishbone?
Re: What's this...
Postby Specky » Mon 22.11.2010, 14:10
Is the second one a chassis to tub rear spacer...
Re: What's this...
Postby ashm » Mon 22.11.2010, 16:23
muley: nope
Specky: nope, but warmer!
Ad
ashm
Re: What's this...
Postby Monty » Mon 22.11.2010, 21:14
1st pic, a clip for a vaccum hose :?
the 2nd pic, is it a spacer for packing out one of thr hood seal :?
Re: What's this...
Postby steve matthews » Mon 22.11.2010, 23:30
Does the first live near the gas tank?
The second door hinge spacer.
Steve
steve matthews
Re: What's this...
Postby ashm » Tue 23.11.2010, 11:31
Hmm... I thought the first one would be easy! You'll kick yourself... ;)
As for the second one: you're right in thinking it's a shim, but for where?
Adam
ashm
Re: What's this...
Postby Monty » Tue 23.11.2010, 18:06
is the 1st pic the clip for the accelerator cable?
and is that shim made of metal?
Re: What's this...
Postby inkitin » Tue 23.11.2010, 20:02
Is the second one the steel plate at the bottom of the A-Panel fixing? :?
If it is, it's somewhat shinier than mine are !
91 SE Calypso Red
inkitin
Re: What's this...
Postby whippit » Tue 23.11.2010, 23:35
second one front bumper shim, me think,
whippit
Re: What's this...
Postby ashm » Wed 24.11.2010, 13:19
The second one's made of plastic. And it's 1.6mm thick, apparently.
If you can guess one of them I'm happy to tell you what the other one is - feels like I underestimated the difficulty somewhat!
Adam
ashm
Re: What's this...
Postby Specky » Wed 24.11.2010, 21:12
I owe you all an apology :(
the heater switch wasn't off the M200 as well, I've just found my M200 pics.... :oops:
Sorry about the lines, but I had to protect the picture a bit.
Bugger...
Re: What's this...
Postby Andy_J » Wed 24.11.2010, 22:13
Heather switch is off an LC :-D
90H BRG SE 48,000 Miles
Andy_J
Re: What's this...
Postby ashm » Wed 01.12.2010, 01:46
Ok, I appear to have killed the thread! :(
So to give it a nudge, #2 is an A-panel mounting shim (A100B2509K)
and if you raise the bonnet and stand in front of the car you should (probably) be able to see part of #1.
Adam
ashm
Re: What's this...
Postby Specky » Wed 01.12.2010, 09:04
I'd like to see you raise the bonnet and not stand in front of the car... :lol:
Re: What's this...
Postby inkitin » Wed 01.12.2010, 20:09
inkitin wrote:Is the second one the steel plate at the bottom of the A-Panel fixing? :?
ashm wrote:So to give it a nudge, #2 is an A-panel mounting shim (A100B2509K)
Adam
:poke: :(
91 SE Calypso Red
inkitin
Re: What's this...
Postby Dave Eds » Wed 01.12.2010, 20:58
I did wonder Roland :-D
Crack on then mate :wink: !
Re: What's this...
Postby steve matthews » Wed 01.12.2010, 23:12
Sorry can't find it on my Fed car.
Steve
steve matthews
Re: What's this...
Postby ashm » Thu 02.12.2010, 15:25
Adam
:poke: :(
Close, but not quite!
Apparently the steel plate at the bottom is B100B1262F.
The part in the photo is a plastic shim and goes at the top of the A-panel, as below:
However, the parts guide and the service manual seem to show different things, and neither quite matches up with my car... Anyway, you were closer than anybody else!
Adam
ashm
Return to Picture Gallery
