by abmunro » Tue 15.09.2009, 13:32
Took Elan for MOT today after spending 2 hours yesterday sorting handbrake.
Sailed through no problem
Mileage now 24013
Very happy
abmunro on Thu 17.09.2009, 20:06, edited 1 time in total.
abmunro
by GeoffSmith » Wed 16.09.2009, 22:16
Mine too but advisary that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
The emissions were strange as I had just fitted brand new plugs, O2 sensor and air filter but CO & HC levels went up!
- Code: Select all
Year miles CO HC
2007 35414 0.432% 69ppm
2008 37599 0.423% 95ppm
2009 39205 0.605% 112ppm
- Kitty Fiddler
by surfboardfiller » Thu 08.10.2009, 09:54
GeoffSmith wrote:Mine too but advisary that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
- Code: Select all
Year miles CO HC
Did you take it to the same place. I got a fail on mine some years ago and left the car in to be 'fixed' and there was nothing wrong, they tested again and it passed. Didn't do it right the first time!
ABM, your car should be in top condition now, especially after the money you have spent on it.
surfboardfiller
by abmunro » Thu 08.10.2009, 11:03
I guess your right!!
abmunro
by GeoffSmith » Fri 10.09.2010, 18:59
In 2009 GeoffSmith wrote:Mine too but advisory that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
A couple of 1.6mm fibreglass wheel spacers were added to get around caliper proximity problem. Minor problem as n/s Wilwood caliper was weeping - bloody NPT taper connections and non-handed calipers means the o/s caliper exit angle of the 90° connector is spot on but the n/s is 180° out so I've re-cut the connector thread by an extra half turn and everything is now spot on. CO levels slightly down but HC levels still increasing.
- Code: Select all
Year miles CO HC
2010 40874 0.477% 127ppm
- Kitty Fiddler
by dapinky » Sat 11.09.2010, 09:22
Geoff,
At this rate, by my reckoning you'll have to consider a HG change before the MOT test in 6 years time
- LEC Administrator
by chipp » Fri 14.01.2011, 23:20
second year running, straight through. you little beauty.
chipp
92SE written off
95S2 sold
91SE sold
chipp
by GeoffSmith » Wed 14.09.2011, 19:38
- Code: Select all
Year miles --CO-- --HC--
2011 41770 0.539% 120ppm
Limit 3.500% 1200ppm
No problems and sailed through (but less than 1000 miles this year
- Kitty Fiddler
by Stef » Thu 15.09.2011, 07:30
Wow
Surprised you got them ot of the garage with that sort of un-used mileage!
Blipi - Currently 151,000 miles. MOT around Christmas. Will let you know
Men are like a fine wine.
Stef
- TVR/PistonHeads Ambassador
by Peter_W » Thu 15.09.2011, 08:05
GeoffSmith wrote:- Code: Select all
There's emissions testing where I live - for the Elan it would need to be less than 1.000% CO and 220ppm HC...but I could have a missing handbrake and non-functional calipers and they wouldn't notice or care.
Peter_W
by Rambo » Thu 15.09.2011, 08:52
GeoffSmith wrote: No problems and sailed through (but less than 1000 miles this year
Next you'll be telling us you have grey hair and drive a lorry for a living
- Don't push me
by JonT » Sun 25.09.2011, 08:57
Just had mine MoT'd. Last year emissions were CO 1.537%, HC 112ppm.
This year with an O2 sensor fitted and the Everest swapped to a 1499 map:
CO 0.58%, HC 42 ppm
JonT
by GeoffSmith » Wed 23.11.2011, 23:36
- Code: Select all
1998 13770 0.0 % 0ppm
1999 16515
2000 24206 0.0 % 0ppm
2001 24581
2002 25754
2003 28106
2004 29199
Found some old MoT printouts
- Kitty Fiddler
by baldyash » Thu 24.11.2011, 17:40
Just had mine MOT'd woop woop! Passed no advisiories. Sad thing is though I've only done 1100 miles since the last one. Note to self----Must use the Elan more!
baldyash
by Rambo » Fri 25.11.2011, 18:04
Nearly 21 years old, over 100k on the clock and sailed straight through its MOT
No advisories either with about 4000 miles covered since the last MOT
- Don't push me
by GeoffSmith » Wed 05.09.2012, 19:01
- Code: Select all
2007 35414 0.432% 69 ppm
2008 37599 0.423% 95 ppm
2009 39205 0.605% 112 ppm
2010 40874 0.477% 127 ppm
2011 41770 0.539% 120 ppm
2012 42296 0.512% 97 ppm
Limit 3.500% 1200 ppm
No problems and sailed through again.
- Kitty Fiddler
by dapinky » Wed 05.09.2012, 19:16
At 526 miles in a year I'm not surprised
(especially since nearly 200 of them was going to our 'local' meet)
- LEC Administrator
by HJ2 » Wed 05.09.2012, 20:34
In the Netherlands CO threshold is 0.5% so you can see why this is an exiting day every year without kat's!
by TrevorB » Wed 06.02.2013, 18:45
'Merlot' had MOT today and sailed through with no advisories - hooray
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
- Wannabe Princess
Return to General
