MOT - sailed through
Postby abmunro » Tue 15.09.2009, 13:32
Took Elan for MOT today after spending 2 hours yesterday sorting handbrake.
Sailed through no problem
Mileage now 24013
Very happy :banana: :banana:
abmunro
Re: MOT - sailed trough
Postby GeoffSmith » Wed 16.09.2009, 22:16
Mine too but advisary that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
The emissions were strange as I had just fitted brand new plugs, O2 sensor and air filter but CO & HC levels went up! :smt017
Code: Select all
Year  miles  CO      HC
2007  35414  0.432%   69ppm
2008  37599  0.423%   95ppm
2009  39205  0.605%  112ppm
Postby surfboardfiller » Thu 08.10.2009, 09:54
GeoffSmith wrote:Mine too but advisary that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
Code: Select all
Year  miles  CO      HC
Did you take it to the same place. I got a fail on mine some years ago and left the car in to be 'fixed' and there was nothing wrong, they tested again and it passed. Didn't do it right the first time! :roll:
ABM, your car should be in top condition now, especially after the money you have spent on it. :-D
surfboardfiller
Re: MOT - sailed through
Postby abmunro » Thu 08.10.2009, 11:03
I guess your right!!
abmunro
Postby GeoffSmith » Fri 10.09.2010, 18:59
In 2009 GeoffSmith wrote:Mine too but advisory that calipers are close to wheels.... bl**dy iron wheel weights have shifted and scored the caliper - bring back lead ones I say.
A couple of 1.6mm fibreglass wheel spacers were added to get around caliper proximity problem. Minor problem as n/s Wilwood caliper was weeping - bloody NPT taper connections and non-handed calipers means the o/s caliper exit angle of the 90° connector is spot on but the n/s is 180° out so I've re-cut the connector thread by an extra half turn and everything is now spot on. CO levels slightly down but HC levels still increasing. :(
Code: Select all
Year  miles  CO      HC
2010  40874  0.477%  127ppm
Postby dapinky » Sat 11.09.2010, 09:22
Geoff,
At this rate, by my reckoning you'll have to consider a HG change before the MOT test in 6 years time :(
Postby chipp » Fri 14.01.2011, 23:20
second year running, straight through. you little beauty. :clap:
chipp
92SE written off
95S2 sold
91SE sold
chipp
Postby GeoffSmith » Wed 14.09.2011, 19:38
Code: Select all
Year  miles  --CO--  --HC--
2011  41770  0.539%  120ppm
Limit        3.500% 1200ppm
No problems and sailed through (but less than 1000 miles this year :oops: )
Postby niall » Wed 14.09.2011, 21:46
Mine sailed through last Saturday.
Mileage 20600. :-D :D :-D
niall
Postby Stef » Thu 15.09.2011, 07:30
Wow :shock: Surprised you got them ot of the garage with that sort of un-used mileage! :-D
Blipi - Currently 151,000 miles. MOT around Christmas. Will let you know ;-)
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Peter_W » Thu 15.09.2011, 08:05
GeoffSmith wrote:
Code: Select all
There's emissions testing where I live - for the Elan it would need to be less than 1.000% CO and 220ppm HC...but I could have a missing handbrake and non-functional calipers and they wouldn't notice or care.
Peter_W
Postby Rambo » Thu 15.09.2011, 08:52
GeoffSmith wrote: No problems and sailed through (but less than 1000 miles this year :oops: )
Next you'll be telling us you have grey hair and drive a lorry for a living :twisted:
Postby JonT » Sun 25.09.2011, 08:57
Just had mine MoT'd. Last year emissions were CO 1.537%, HC 112ppm.
This year with an O2 sensor fitted and the Everest swapped to a 1499 map:
CO 0.58%, HC 42 ppm 8)
JonT
Postby GeoffSmith » Wed 23.11.2011, 23:36
Code: Select all
1998  13770  0.0  %    0ppm
1999  16515
2000  24206  0.0  %    0ppm
2001  24581
2002  25754
2003  28106
2004  29199
Found some old MoT printouts
Postby baldyash » Thu 24.11.2011, 17:40
Just had mine MOT'd woop woop! Passed no advisiories. Sad thing is though I've only done 1100 miles since the last one. Note to self----Must use the Elan more! :)
baldyash
Postby Rambo » Fri 25.11.2011, 18:04
Nearly 21 years old, over 100k on the clock and sailed straight through its MOT :D No advisories either with about 4000 miles covered since the last MOT :D
Postby GeoffSmith » Wed 05.09.2012, 19:01
Code: Select all
2007  35414  0.432%   69 ppm
2008  37599  0.423%   95 ppm
2009  39205  0.605%  112 ppm
2010  40874  0.477%  127 ppm
2011  41770  0.539%  120 ppm
2012  42296  0.512%   97 ppm
Limit        3.500% 1200 ppm
No problems and sailed through again.
Postby dapinky » Wed 05.09.2012, 19:16
GeoffSmith wrote:
Code: Select all
At 526 miles in a year I'm not surprised :shock: (especially since nearly 200 of them was going to our 'local' meet)
Postby HJ2 » Wed 05.09.2012, 20:34
In the Netherlands CO threshold is 0.5% so you can see why this is an exiting day every year without kat's! :shock:
Postby TrevorB » Wed 06.02.2013, 18:45
'Merlot' had MOT today and sailed through with no advisories - hooray :clap:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Return to General
