Throttle Position Sensor
Re: Throttle Position Sensor
Postby Brit-Car-Nut » Mon 27.04.2015, 18:10
I looked through a lot of parts books and found the throttle body on the M100 is from the 1987 Isuzu I-Mark Turbo and the TPS that is shown for it looks like the one used in the M100.
The TPS for the '91 Isuzu Impulse Turbo is not the same as the one used in the M100.
The 1987 Chevrolet Spectrum Turbo also uses the same part.
The numbers offered are: TH277 by Standard, 8944331860 and 94433186 from Isuzu and GM, SERA4848 is the Hitachi part number for the Th277.
AC Delco used number 2134486 or 19236540.
The GM and Isuzu numbers are all shown to be obsolete.
I ordered a SERA4848 and will let everyone know if it really is a correct match
Postby Rob P » Tue 28.04.2015, 11:49
Brit-Car-Nut wrote:I looked through a lot of parts books and found the throttle body on the M100 is from the 1987 Isuzu I-Mark Turbo and the TPS that is shown for it looks like the one used in the M100.
Thanks BCN, I look forward to further update, currently car behaving itself but I do feel that this is an area which needs something newer deploying
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Postby Brit-Car-Nut » Sat 09.05.2015, 05:10
The story so far:
The TH277 Throttle Position Sensor finally arrived and the actual sensor is probably fine but the attaching wings are a lot longer than ours and it doesn't have a harness because it was used with a plug in connector.
Our TPS and the TH277
The TH277 is a Hitachi SERA484-8 while our TPS is a SERA484-2
So, I went back into the catalogs and under the Isuzu I-Mark TURBO in 1989 there is a listing for a Standard Motor Products TH332 which cross references to TPS4085 and Airtex Wells # 5S5200. It supposedly also fits the Chevy Spectrum Turbo.
Looks familiar?
The TH332 is a Hitachi SERA484-2a and it looks to be identical to ours.
The TH332, TPS4085 and the 5S5200 are not inexpensive at Rock Auto $195.99 for the TH332 or $189.79 for the 5S5200 but a sight less expensive than the Lotus A100E6432S at £237.88
I found suppliers on eBay, Google, NAPA, Auto Zone and Amazon. Auto Zone seems to have one of the lowest price in the US at $174.99 - It is a Special Order Item so don't expect to walk in and pick one up.
Amazon has a listing for $167.76 and free shipping.
There is a reference to Isuzu part numbers 8943146060, 8943607820 (GM # 94314606 and 94360782).
So, NEW TPS units are still available from Lotus, Rock Auto, Auto Zone and Amazon and the TH277 is probably the correct electronics, jut the wrong attachment and connection, but it is a 4 wire device. The one I purchased was only $50.00 so not a big waste in the overall scheme of research. If anyone wants it, they can buy it from me for $50.00 + whatever the shipping to your address will cost. I will eventually sell it on eBay.
I hope this info helps.
Postby Elanlover » Sat 09.05.2015, 13:53
Good research! :cheers:
Postby Scott » Wed 17.05.2017, 06:10
Hello, I am in the need for a new TPS sensor. Should I go through SJ's one or RockAuto's?
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
''L.O.T.U.S - Let OThers UnderSteering''
Scott
Postby Scott » Wed 17.05.2017, 06:12
Brit-Car-Nut wrote:The story so far:
Hello, I am in the need for a new TPS sensor. Should I go through SJ's one or RockAuto's? Have you tried any of the ones you refer?
2001 Volvo S40 1.6
Scott
Postby Brit-Car-Nut » Wed 17.05.2017, 12:33
SJ's price is no worse than the US versions. YOu should probably go that route
Postby Scott » Wed 24.05.2017, 05:53
Brit-Car-Nut wrote:SJ's price is no worse than the US versions. YOu should probably go that route
Ok cool! I'm buying next week!
Does anyone know if the car is shaking at high speeds ( >80-100km ++ ) what could it be?
2001 Volvo S40 1.6
Scott
Postby muley » Wed 24.05.2017, 08:47
Buckled/out of balance wheel?
Postby Fredjohn » Wed 24.05.2017, 10:02
In addition you may wish to inspect your tyres for flat spots. After storing for a while without proper support for the tyres they will become flat on one side. This can also cause shaking: I know I'm currently suffering the same problem and trying to eliminate it. Had wheels checked for straightness (OK), but 2 tyres had flat-spots, so 2 new ones ordered. Toyo Proxes T1R in case you want to know!
Postby lotusflasherman » Wed 24.05.2017, 10:34
Fredjohn wrote: Toyo Proxes T1R in case you want to know!
Good decision... done a couple of thousand miles on mine and very good in wet and dry, and I didn't pay a lot for them. Having fun trying to wear them out ...
Postby Fredjohn » Wed 24.05.2017, 10:45
Thanks Phil....unfortunately the tyres (all Proxes) were only 4/5 years old and had loads of wear left in them.....Need to buy some tyre supports!!
:offtopic: sorry guys.
See you Saturday Phil.
Postby Scott » Fri 26.05.2017, 05:34
Well in that case I definitely need a new set of tyres as mine are 5 year old as the car is mostly in the garage using it for weekends or rainy days (yes I have towels always inside the car haha)
2001 Volvo S40 1.6
Scott
Postby matts1972 » Thu 27.06.2024, 21:29
Reviving this old thread.
I can confirm that the SERA484-10 is a good replacement for our SERA484-2 TPS.
At the moment there is a good supply of SERA484-10 clones available and I got mine for €38 incl. shipping from China. A genuine TPS for the M100 would have cost >€300.
You only need to swap the connector from the old sensor and make sure to solder the pins in a different order (see photos). You do not need to connect the blue wire, as it is unused.
The old rubber sleeve fits on the new sensor, so the resulting TPS looks like an original.
Notice the original wire colour order on the right
China SERA484-10 TPS clone with connector taken from broken Elan TPS
matts1972
Postby niall » Sat 29.06.2024, 16:27
Thanks Matts.
niall
Postby rob/d » Sun 18.08.2024, 15:41
Hey Matt .
Do you have a linky for that TPS from china ?
I suspect mine is faulty as i am super rich on tickover , but it has gradualy got there over a few MOT's , so i now suspect the throttle sensor .
Testing it tomorrow , but if there's a cheap version available , i might just swap it anyway .
Is it this ?
Looks correct .
https://www.aliexpress.com/item/1005007 ... ry_from%3A
Thanks Matt .
rob/d
Postby matts1972 » Sun 18.08.2024, 16:13
rob/d wrote:Hey Matt .
Is it this ?
Looks correct .
Thanks Matt .
Hi Rob,
Yes, looks good. I got mine from this seller:
https://de.aliexpress.com/item/10050031 ... pt=glo2deu
Matt
matts1972
Postby rob/d » Sun 18.08.2024, 18:41
Cool beans , thanks .
rob/d
Postby rob/d » Mon 19.08.2024, 16:53
Tested the TPS , working as it should .
.39 volts with ignition on , but not running , 0.4 volts output at idle running .
So that's the Timing set properly ,TPS , CTS , ATS ,new plugs and MAF tested and functioning as they should , i replaced the coolant sensor and air temp sensor because they're cheap anyway .
Drinking petrol like a sailor on shore leave .
Richer than Elon .
Thanks Matts .
rob/d
Postby roj » Tue 25.03.2025, 16:41
Hi Rob,
Did you ever resolve the issue of the car running rich?
Thanks,
Rog.
roj
