Stick on number plate
Postby antelope » Fri 10.09.2010, 14:48
Has anyone taken the front number plate off and replaced it with a stick on version? I imagine it would look better perhaps? ANd the shape of the front end lends itself as the stick on won't be too inclined to the horizontal.
antelope
Re: Stick on number plate
Postby Rambo » Fri 10.09.2010, 15:03
I've thought about it but never got further than that.
I think it would look even better on the bonnet as per the E-type but I gather this would be illegal these days as it is not in a vertical plane. Correct me if I'm wrong Dapinky ;-)
Postby dapinky » Fri 10.09.2010, 16:35
Rambo wrote:I've thought about it but never got further than that.
Mark, unfortunately you're correct :(
Due to the age of the elan, the plate has to be fitted in a vertical plane, and have reflective background. Back in the days of the E tpye, it was legal to do.
That said, I've seen plenty of cars with numbers stuck on (MX5's Lotus Elite/Eclat) and never thought about pulling them over for it - but it all depends on the copper who sees it, I suppose, and what they view as important.
My view is that as long as it's readable with ease, then it isn't a huge issue, but it is unlawfull.
Postby MattDon » Fri 10.09.2010, 17:35
ive done it but stuck it just slightly higher than the origional, so its not unreaonable, passed a couple of mot's with it and not been stopped. didnt realise it was an issue.
please use email for contact
MattDon
Postby Jackonicko » Fri 10.09.2010, 17:43
The problem is that the best place for such a plate would be exactly where the nose badge now is.
Jackonicko
Postby dapinky » Fri 10.09.2010, 18:43
MattDon wrote:..... passed a couple of mot's with it and not been stopped. didnt realise it was an issue.
It's one of those odd bits of law that England is full of!
The positioning of the plate is designated under "Road Vehicle Licensing Regulations", and the MOT test doesn't concern them - but it is done under the Road Traffic Act and "Construction & Use Regulations".....
As such, technically a car will pass an MOT with the numbers scribbled in chalk on a blackboard held on (securely!) with chewing gum - as long as the script is correct, and the plate isn't dangerous......
....however, to comply with the Licensing Regs, it has to be vertical, reflective, etc etc etc
Postby RayD » Fri 10.09.2010, 20:29
Postby Andy_J » Fri 10.09.2010, 21:59
Got a stick on plate on my elan. it is in the same place as the original, so it is vertical, but not flat. Passes MOT evry year.
Failed last year on the rear number plate not being secure and vertical :lol:
90H BRG SE 48,000 Miles
Andy_J
Postby antelope » Fri 10.09.2010, 22:17
A stick on would fit on that cross section above the one holding the indicators wouldn't it? Not quite the e type effect, but maybe an improvement.
antelope
Postby ashm » Mon 13.09.2010, 00:01
A guy I know has been driving around in his Corvette Z06 for a couple of years with a standard front plate... sat on his dashboard inside the windscreen. Nothing whatsoever on the front of the car. I'm going to laugh the day he gets in trouble for it, but so far this has failed to happen. And yes, we've told him to get it sorted.
Adam
ashm
Postby Rambo » Tue 14.09.2010, 21:00
Too much time on your hands Ray :twisted: Looks good though ;-)
Postby GeoffSmith » Tue 14.09.2010, 22:36
Monty's got a strap-on - it's held on with cable ties. :twisted:
Postby DeeAitch » Wed 15.09.2010, 20:21
ashm wrote:A guy I know has been driving around in his Corvette Z06 for a couple of years with a standard front plate... sat on his dashboard inside the windscreen. Nothing whatsoever on the front of the car. I'm going to laugh the day he gets in trouble for it, but so far this has failed to happen. And yes, we've told him to get it sorted.
Adam
I knew a guy with an MR2 did the same - ran with it so long that the Sun had melted it into the shape of the dash. He was never stopped - and never got any speeding fines either :P
I just know if I tried it I'd get pulled on day 1 :twisted:
DeeAitch
Postby Rusty » Wed 29.09.2010, 20:06
Interesting, what would the fine be for breaking construction and use regulations with a plate on the dash that probably can't be read easily by a camera (maybe 60£ and no points?) as opposed to a speeding fine with a standard plate and getting points? Is the trade off worth looking at?
When washing the car have some of you accidentally sprayed the hose upwards on the rear plate cover and had foggy mist to deal with?... :twisted:
Rusty.
Rusty
Postby RayD » Tue 01.03.2011, 20:00
I’m just about to fit a new number plate at the front, and wondered …
Is there a reason for the UK front number plate screws being at 14½” centres … as opposed to 19” ish?
Is the body thickness uniform across the front bumper?
Has anyone got the screws in the “corner” of the plate rather than at 14½?”
Postby dapinky » Tue 01.03.2011, 20:31
RayD wrote:I’m just about to fit a new number plate at the front, and wondered …
No!
Don't know!
Yes & No (red and blue, in that order!)
Postby RayD » Tue 01.03.2011, 20:45
Thanks Dave,
I was just concerned they may have fitted some blocks at 14" ... and have it paper thin where the screws ought to have been ... away from the letters ... and near enough to the end for the plate to follow the line on the bumper.
Does anyone else have them at the ends?
Recommended
Postby inkitin » Tue 01.03.2011, 21:15
RayD wrote:I was just concerned they may have fitted some blocks at 14" ... and have it paper thin where the screws ought to have been ... away from the letters ... and near enough to the end for the plate to follow the line on the bumper.
Mine are at 15.75" centres and always have been, going by the fact that there are no other holes in the bumper. :?
91 SE Calypso Red
inkitin
Postby theelanman » Wed 02.03.2011, 01:35
I think the thing with plod is screws put in places they wouldnt normally be to suit vanity plates.....
i thing you can stick them at any centre you like but if they are not symetrical then it becomes obvious....
as for on your bonnet....personally I dont like the look.......
on the 67 theyre fixed to the front grill.......under the bumper.....hardly visible at all....certainly not by cameras....but legal for that 'age' of car......
if your talking bad number plates....just remember the alfa 156....they designed the front end....then thought oh sh!te where do we put the number plate....ouch...looks good without....looks fugly with..(the front end that is)
Postby RayD » Wed 02.03.2011, 10:19
theelanman wrote:
I think the thing with plod is …….
As for on your bonnet....personally I don’t like the look.......
If you’re talking bad number plates....just remember the Alfa 156…….
Gareth,
I didn’t imagine there’d be a legal requirement for hole spacing … :D
I don’t like the look of it on the bonnet either … I laid the new plastic one just above the badge and it’s the only thing you see when you look at the front of the car.
I know what you mean about the Alfa’s.
