turbo replacement
turbo replacement
Postby PECKHS » Tue 18.01.2011, 02:51
recently there was smoke again after my engine rebuilt, and this time i have narrowed down to a leak in the turbo.
i am thinking of changing the turbo and have trouble finding a new one...
i'm not keen with a used turbo cos i'll never know the condition and am not sure if rebuilding will be a good idea.
i've tried searching the net for a new turbo but couldn't find any..
anyone has bought a new turbo before?
alternatively, is there any other suitable turbos that is just plug and play(probably wishful thinking on my part)
appreciate any help
tks
peck
PECKHS
Re: turbo replacement
Postby bobbrown » Tue 18.01.2011, 10:15
I think finding a new one is going to be very very difficult if not impossible.
This one is cheap enough and should fit Link not sure if it is survacable but at that price you could rebuild it assuming the compressor, inducer wheels and shaft are OK
These should be similar linkand have asked the guy for some more details. OK its 2 but if they are correct then you would have no problem selling one on as they are new.
Edit NOT an option as the guy cam back to me and these are not water cooled.
You may want to see if you can find a new cartridge as this replaces all but either end which is what Fetnas did with his last year
FYI this is the stock turbo sizes for the compressor wheel and turbine.
compressor
38.53 52.50
turbine
42.70 52.48
Pacific Blue N/A
Postby PECKHS » Wed 19.01.2011, 07:11
bobbrown wrote:I think finding a new one is going to be very very difficult if not impossible.
compressor
38.53 52.50
turbine
42.70 52.48
tks bob, but according to my mechanic it seems that the shaft is worn. if it is true, then rebuilding is not possible.
there is a used turbo in ebay, but i'm worried about the condition.
was thinking of changing to GT2554 as some of you have done, but will need to let the workshop that has more experience with turbo to make an assessment first as many parts need to be fabricated if i'm not wrong
PECKHS
Postby ailwyn » Wed 19.01.2011, 10:06
Assuming it's the same fitting as the LGM upgrade then I still have a kit available here.
Ailwyn
Postby bobbrown » Wed 19.01.2011, 16:10
PECKHS wrote:tks bob, but according to my mechanic it seems that the shaft is worn. if it is true, then rebuilding is not possible.
I assume you mean the part just after the turbine which seals the exhaust side
This one is OK as the groove closest the turbine is square but can end up rounded and you will not be abe to keep the oil in hence the smoke
As for the the turbo on ebay you pay your money and take you chance but it is cheap enough then you do not lose too much and you have a good starting point for a rebuild and may save you money but its your call.
A GT2554 will still introduce more turbo lag than the current IHI turbo as the turbine is that much larger in diameter and thus the weight increase and I do not think you can off set the extra weight v ball bearing as the weight will have a bigger impact than the bearings.
BTW does this mean your engine rebuild was not really necessary?
Pacific Blue N/A
Postby PECKHS » Thu 20.01.2011, 02:00
ailwyn wrote:Assuming it's the same fitting as the LGM upgrade then I still have a kit available here.
Ailwyn
tks ailwyn, but i believe it is cheaper if i got the stuffs fabrcated locally. labour is much cheaper here
PECKHS
Postby PECKHS » Thu 20.01.2011, 02:12
i have not gotten a chance to see the turbo yet, but according to my mech the shaft is worn and oil is leaking because of that. will not be able to do much at the moment cos my mechanic's partner just passed away and they are still busy with the funeral...
i'm not particularly keen to change to a garrett now unless it is absolutely necessary, as i would like to get a feel of the elan on stock specs before i consider what i would like to improve.
the engine rebuilt was still necessary, as the piston was not fitting tightly. funny thing is we did not see any oil at the turbo outlet when we dismantled the engine.
nevertheless, if i'm still unable to locate a new or newish turbo, i'll probably just buy the one on ebay... i really regret not having taken the advise and bought the turbo from abmunro...
cheers
peck
PECKHS
Postby PECKHS » Wed 26.01.2011, 13:34
So I could not find any new turbo, not even the RHB5 VI78. I have tried to contact Dave at lotusm100parts. He will check and revert over the weekend. Crossing my fingers that he at least has a good used one .
PECKHS
Postby PECKHS » Sun 06.02.2011, 16:09
ok, so i just came back from holiday and got the bad news from dave...he hasn't got any turbo for the elan
i'm thinking of getting this
http://cgi.ebay.co.uk/TURBO-LOTUS-ELAN- ... 336310fb3a
but the seller is not willing to ship to singapore.
can anyone help to receive and resend it to singapore????
i will pay for the shipment before it will be send .
tia
PECKHS
Postby bobbrown » Sun 06.02.2011, 17:23
If you need this sent on I do not mind doing it as I have sent stuff to Singapore in the past.
I can check it over before shipping to make sure it is OK or at least as far as an external examination is concerned and check the shaft for play.
Email me if you want to go ahead and I can email you back my address
Regards Bob
Pacific Blue N/A
Postby Artaban » Mon 07.02.2011, 00:32
I just wanted to add that last year I was in a similar position with a turbo that finally died. In the end I sent two secondhand turbos off to Turbo Technics www.turbotechnics.com 01604 705050. These had been working when they were removed from their owners cars but in Turbo Technics view they were just too far gone to salvaged or rebuilt. Over the years they have done quite a few Elan turbos but told me that they are getting to an age now where they are becoming increasingly difficult to rebuild cheaply. They offered to build me a completely new one or use the one i sent and replace everything inside plus some of the casing. I opted for the latter and they did a great job but it cost £625 + VAT. (price as at June 2010). When they sent it back it looked totally new to me and they guaranteed it 2 years. Like any secondhand part its a bit of a gamble from ebay but it may be worth asking Turbo Technics if they can build you a new one.
Hope it works out for you.
Andrew
Artaban
