can anyone check these out please
Postby mickmick » Wed 10.01.2007, 18:04
if i get it right (and if i do thank you Geoff)
i'm asking as i'm not 100% happy with the car at the mo
the boost guage only goes to 0.5
i#m not sure if my throttle is set up right
my timing seems a little high
many more to add
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Postby mickmick » Thu 11.01.2007, 18:51
27 views and not one reply yet
cmon people, help me out
even a rundown of what to look for would help
sorry mum :(
mickmick
Postby Doug » Thu 11.01.2007, 21:36
it must be the avtar freaking people out ??
Postby mickmick » Thu 11.01.2007, 22:28
ok ok, i'll change the avatar of me and the woman far too good for me
this any better?
sorry mum :(
mickmick
Postby dapinky » Thu 11.01.2007, 23:08
I think you need to change your location aswell (either that, or learn proper Geography ;-) )
I mean......... since when was Doncaster in Warwickshire? :-D :-D :-D
Postby Doug » Thu 11.01.2007, 23:35
mickmick wrote:this any better?
:smt066
Postby mickmick » Thu 11.01.2007, 23:57
cmon folks, this is meant to be helping me fix my car!!!!!!!
btw, location changed :lol: :lol: :twisted: :twisted: :lol: i wipe me arse on warwickshire
sorry mum :(
mickmick
Postby GeoffSmith » Fri 12.01.2007, 00:19
mickmick wrote:warwickshire
Isn't that where that bloke who writes incomprehensible school plays comes from? :evil: Bart or someone! :twisted:
Mick,
I've had a quick look at your runs. I'm no expert on the interpretation side (John_W and ESM are the boys) but it looks like you're getting boost up to 0.6 or so - it could be your gauge is reading low. Your power does look a bit low but you weren't up to maximum revs and if there was any sort of upward incline, that would tend to decrease the numbers.
One question that should be asked is, have you set your base timing? Everything that the ECU does assumes that this is spot on. I've come across quite a few people who have had problems but the timing hadn't been set. If you haven't done it recently, it would be well worth checking, otherwise, can you let us know a bit more about what you think is wrong.
Sorry to have been so little help, but glad the interface is working! :-D
Geoff
Postby ailwyn » Fri 12.01.2007, 03:59
geoffsmith wrote:it could be your gauge is reading low.
Don't go by the gauge, they are useless, mine shows a max out at .75 when in fact the ECU is seeing over .9
I agree with Geoff, you need to post more symptoms or suspicions and then the ES data can be analysed to prove or disprove a theory.
Also, get the base timing reset, remember to put the car in service mode first.
Ailwyn
Postby mickmick » Fri 12.01.2007, 11:43
ok,
i'm under the car today sorting out the front rubber lip (price is down to £13 inc VAT and postage now)
after that i'll have a read of what to do with the base timing, make sure i've got the tools to do it (and if i havent its charlie browns/halfrauds/ebay to get them)
set it right
do some more runs
and ask again
Cheers for the replies to the content of the ORIGIONAL thread
Mick
sorry mum :(
mickmick
Postby Siegreen » Fri 12.01.2007, 15:34
dapinky wrote:I think you need to change your location aswell (either that, or learn proper Geography ;-) )
OI.!!!!! :censored:
Theres more than one of us on here!!!
You hold him Mick an I'll kick him in the shins!! :-D :-D
I fart in your general direction! You mother was a hamster and your father smelt of elderberries!"
Azure Blue S2 No. 452
Siegreen
Postby GeoffSmith » Fri 12.01.2007, 18:29
Mick and Si, gun toting Southerners the pair of you! :-D
Postby dapinky » Fri 12.01.2007, 19:56
And neither of you frighten me anyway!
God built Warwickshire first, then added other bits, hence its in the Midlands - simple Maths, really!
P.S. - I like it so much, I now live in Somerset! :roll:
Postby TheBard » Thu 29.03.2007, 19:19
I agree completely, and moved to Washington D.C.!!!
You can take the lad out of Warwickshire, but you can't take Warwickshire out of the lad!
Oh, and Mick, they look like scans, how'd you do them, if you find my earlier efforts, I did third gear runs at wide open throttle from almost stalling to red line. That gives a nice range to check over.
Cheers,
Ian
TheBard
Postby ESM » Thu 12.04.2007, 21:07
I had a look and it looks like a stock setup running pretty well.
    No codes are set
    The CTS & MAT agree to within a degree or so at startup (well done for logging when cold, most people warm it up first)
    The boost reaches programmed levels of >0.6bar in the runs, (you need more revs to hit 0.65bar)
    Negligible knock
    The Baro reading is reasonable
    The power levels look believable and consistent with stock performance
    Normal voltage
ESM
Postby mickmick » Fri 13.04.2007, 08:33
Cheers for looking at them ESM fella,
good to find out from the man that my car is running well, i know i have a slight issue with the boost guage as a day ago i did two runs, unfortunately without the lappy logged in, and on the way out i was getting 0.7 indicated boost, but on the way back i was getting 0.5 indicated.
Also did another paperclip test as i had a code 34(maybe, not sure about number but it was a MAP one) however that has not come back again, so maybe things are A ok
Mick
sorry mum :(
mickmick
Postby Enright » Mon 23.07.2007, 22:05
After my PC went bang last week, I am now in possession of a new laptop.
So I thought I'd put it to good use and get an Elanscan run in, as I haven't had the facilities to do one for ages.
Anyway here goes. A few different conditions using the Closed Loop Elysium program. Full throttle acceleration in 3rd & 4th at one noteable point around 700s.
It seems a bit odd that it never exceeded 0.85bar boost and 165hp. No knocks either.
Anyone have any thoughts?
Return to ElanScan
