everest chip
Postby GeoffSmith » Sat 25.11.2006, 15:34
surfer - Phil wrote:
geoffsmith wrote:Some people even do it without disconnecting the battery and removing the ECU! :smt018 :wink:
Surely all you need to do is remove the fuse? Save a bit of bother?
I don't even do that Phil. As you would expect and as far as I can tell, there is no power on the MEMCAL with the ignition off, so I change mine in-situ with the ignition off.
Usual cop out clauses apply - DON'T TRY THIS AT HOME CHILDREN!
Postby surfboardfiller » Sat 25.11.2006, 15:50
That's encouraging, I hate the battery compartment, I am sure strange things lurk in there! :o
surfboardfiller
Postby Monty » Sat 25.11.2006, 19:04
I`ve removed mine several times and Dico`s whilst testing with no prob`s. Mind u a do remember JimP blowing a fuse in germany whilst fitting the latest chip :lol:
Postby Dico » Sat 25.11.2006, 19:22
Monty wrote: Mind u a do remember JimP blowing a fuse in germany whilst fitting the latest chip :lol:
Thats the 1st thing that came into my head :shock:
Probably not worth the risk, especially if your'e several hundred miles from home :P
Postby jimp357 » Sat 25.11.2006, 19:28
:cry:
Take it from me, Save yourself loads of stress. Disconnect the battery first.
VORSICHT! Die Nordschleife ist gefährlich.
jimp357
Postby surfboardfiller » Sat 25.11.2006, 20:11
jimp357 wrote::cry:
Surely pulling the fuse out cuts the power (and with ignition off) ensures there is no risk of a surge or short.
Why the hassle of disconnecting the battery and have to deal with the CD player and alarm when re connected? :?
surfboardfiller
Postby GeoffSmith » Sat 25.11.2006, 21:01
jimp357 wrote::cry:
Did you do it with the ECU in situ Jim?
Postby ailwyn » Mon 27.11.2006, 04:18
Had ESM fit mine in Donny last year, IIRC he just pulled the ECU connectors, fitted the chip, re-fitted connectors - no battery disconnection.
Ailwyn
Postby ESM » Mon 27.11.2006, 10:43
Do as I say not as I do :wink:
I had a spare ECU in the boot at Donington...
ESM
Postby GeoffSmith » Mon 27.11.2006, 14:12
ESM wrote:Do as I say not as I do :wink:
:agree: Oh, and he's a damned good runner!
Postby surfboardfiller » Tue 28.11.2006, 13:24
Any chance you can have a look at my car for suitability for a chip next donny?
My brakes may have arrived by then :?
surfboardfiller
Postby ESM » Wed 29.11.2006, 16:36
If its an Elan (M100) so as long as its got a turbo its suitable.
The only question is whether you have anything unsuitable fitted already! :wink:
ESM
Postby clemo » Wed 29.11.2006, 17:24
as long as its got a .........
oh bug*er
clemo
Postby GeoffSmith » Wed 29.11.2006, 17:34
Never mind Clemo. I hear that Alan is going to add to the famous Mountain range in the near future; in addition to the Kilimanjaro and Everest for the SE/S2, he's going to introduce the Bonneville for NA owners. :-D
Geoff
Postby clemo » Wed 29.11.2006, 17:51
your wisdom is wasted on me ...
try a better insult...
wun d@ eye may udstnd txt wkd m8.
clemo
Postby GeoffSmith » Wed 29.11.2006, 17:52
Bonneville salt flats - flat as a witch's tit! :smt043
Postby surfboardfiller » Wed 29.11.2006, 20:56
ESM wrote:The only question is whether you have anything unsuitable fitted already! :wink:
That is the question, is there anything I should look for on the car? Exhaust type etc?
It's an H Reg SE Turbo, 32,000 miles with a ss exhaust, not sure what type or what else as I have only had it 1 year. I just kept everything running nicely as is without any upgrades.
Thanks,
surfboardfiller
Postby ESM » Wed 29.11.2006, 22:15
If the boost is stock (0.65bar maximum) then it'll be ok. The only question is whether a 9929 or a 9930 is the right chip.
To know for sure you would have to get a garage to connect a diagnostic tool (a Tech-1) which would read-out the PROM id or find someone local to you with an ALDL interface and ElanScan which can do the same thing. If you ask on LEC there's a good chance someone close to you will help. Alternatively, if a 9930 has been fitted the mechanic should have written CO (or similar) on the ECU casing, the Lotus instructions said they should anyway, and I have seen it in the wild. You could have a look and if there's no marker go for a 9929 - its not foolproof like the other way though..
If you do get the wrong chip it won't do any harm to the engine but it might be tricky to pass the MOT emissions test (if you replace a 9930 with a 9929) or the idle might get a bit lumpy (if you replace a 9929 with a 9930). The latter can be fixed by adjusting the CO pot.
ESM
Postby ailwyn » Thu 30.11.2006, 01:34
Phil,
We can meet up again and I'll hook up my laptop.
Ailwyn
Everest Chip
Postby algirdas » Thu 30.11.2006, 02:40
Dear Geoff:
I think you got it wrong about the naming of the N/A chip. The Bonneville Salt Flats are home to some of the fastest cars ever seen on this planet.
The new N/A chip needs to be called "Death Valley". :D
Clemo-No offense.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Return to Upgrades
