ESM Chips - Information & Help
Postby XiPHiAS » Wed 18.06.2008, 22:28
Enright wrote:XiPHiAS, which program you use entirely depends on your mood.
You should get a list of which program gives what boost setting. Then:
If you are leaving your car with a garage and you suspect that they may take it out for a spin, turn it down to minimum.
Going for a spirited blast or on a trackday? Turn it up to the max.
It's up to you.
Yeah I see ... I didn't mention there was a display onto the switcherboard. ;-)
XiPHiAS
Postby XiPHiAS » Wed 18.06.2008, 22:32
I have another question ...
After decoding my VIN to see what PROM I have; I've found that my car has the 1944 PROM... and that's weird?
I've imported the car from Germany...
My car has LHD and don't has the big bumpers like they delivered in the US...
XiPHiAS
Postby davidjt » Wed 18.06.2008, 23:14
Often wondered what 1-6 were for! :-D
davidjt
Postby XiPHiAS » Wed 18.06.2008, 23:16
davidjt wrote:Often wondered what 1-6 were for! :-D
You cannot see clearly that round-thingie is a LED display.
XiPHiAS
Postby Enright » Mon 23.06.2008, 15:23
MattDon wrote:Ive got 2 Elan ecu's one's an early 9929 and the other is a 9930, can i just swap the whole lot over (ie metal box with everything in)? the reason i ask is that i have two everest chips and ones a v4.2 9929 and the other is a v4.5 9930. cheers
I think that the 9929 and 9930 have completely different CO potentiometer calibration, so in theory, yes you can swap from one to the other by just changing the boxes over.
In practice, you'll probably need a gas analyser to measure the CO output before you do, and then to adjust the CO pot to bring it back to the original reading afterwards.
I've moved the question to here because Alan is more likely to see it and confirm the above answer.
Postby MattDon » Mon 23.06.2008, 15:33
ive reposted it as i couldnt find it except in your quote, not sure if this is the right place for it as its more of an ecu question but im sure if anyone can answer the question its Alan.
MattDon
Re: ESM Chips - Information & Help
Postby ESM » Sun 31.08.2008, 19:01
It never rains....
Judging by a couple of recent ECU failures that happened soon after switcher installations I have a bad feeling and so I am recalling all switcher kits that have the new version of the EX remote (pictured). I'll refund in full if the kit is undamaged. It might be a coincidence but I don't want to take any chances. I have e.mailed everyone who I believe might be affected but please get in touch if you have slipped through the net.
ESM
Postby chrishewett » Wed 03.09.2008, 07:53
I was going to order an everest so the garage which has my car at the moment put it on their diagnostics and tell me that the prom id is 9099. ANXZ9099 to be exact.
Any idea what I do now?
chrishewett
Postby rip » Wed 03.09.2008, 09:55
chrishewett wrote:I was going to order an everest so the garage which has my car at the moment put it on their diagnostics and tell me that the prom id is 9099. ANXZ9099 to be exact.
Use Elanscan to take a PROM dump & send this to ESM.
Postby Enright » Wed 03.09.2008, 10:46
rip wrote:Use Elanscan to take a PROM dump & send this to ESM.
As Chris had to get the garage to use their diagnostics, maybe he hasn't got Elanscan.
But quoting the above code to ESM may well be enough for him to be able to provide the appropriate upgrade chip.
Postby chrishewett » Wed 03.09.2008, 19:11
You are right, I don't have elanscan as bigpockets havn't delivered the laptop I ordered two weeks ago!
I will try and send a message to ESM and see what happens.
chrishewett
Postby John_W » Wed 03.09.2008, 19:29
Chris,
ESM is in Glasgow at the moment up to his elbows in alternators, and away from home.
However, our new search facility reveals this thread, in which Geoff identifies the anxz9099 as an early 9239 (see here for definition)..
See also this thread, and pjohn151 talking to himself here.
If you have problems meeting MoT emission levels then you need the 9930 SE chip mentioned here. In fact, my personal opinion is that you should always fit a 9930-based Mountain chip to an SE, and take the opportunity to upgrade from your old 9929-spec chip. This will give you a chip based on the latest Lotus specs which were brought out to ensure compliance with later emissions regulations, and so gives you a useful bit of leeway at MOT time. You will have to adjust the CO pot if you replace a 9929-spec chip with a 9930-based upgrade, but that's a doddle.
Postby rip » Wed 03.09.2008, 21:26
If you want to fiddle & are really concerned about emission tests, then upgrade to a 1499 & fit an O2 sensor. The wiring is already in place too.
Postby chrishewett » Wed 03.09.2008, 22:28
Thanks for all the help, what a great forum!
I will digest all this info and report back.
chrishewett
Postby Doug » Wed 03.09.2008, 22:47
good helpful info everyone -- now who's going to drop it into the WIKI?? maybe with a few more directions regarding what's involved in changing the car inself with the new chips in place . . .
Postby Exbury » Thu 11.09.2008, 17:26
John_W wrote:Chris,
As my car is an SE (91) and in the garage and I have no idea which chip is fitted, from what I understand John, is that pretty much forget seeing if the chip is a 9929 or 9930 and just order a mountain chip based on 9930. Then take CO readings before, fit the new chip and tune in the CO pot (I know it failed its last emissions on CO (they were quite high to say the least). Then 'store' the old chip......just in case! As the car is goign for MOT after all this work, I have a feeling that even after tuning its going to have problems and I have always wanted an upgrade chip anyway!!
Exbury
Postby John_W » Thu 11.09.2008, 22:48
Exbury,
My car is an SE which had the old 9929 chip in it. When I put in a mountain chip a few years ago, they were all I think based on the 9930, as that was the chip supplied by Lotus according to the latest Service Bulletin. It ran fine straight away, but idling was a bit lumpy. After a quick confab with ESM, I adjusted the CO pot and all was perfect. I adjusted it by ear rather than with a CO probe in the exhaust, although the latter is probably preferable. Note that previously the CO pot was turned to its minimum to allow the 9929 to pass the MOT. When I fitted the 9930-based Mountain chip I had to move the pot away from its minimum setting to give a bit more fuel at idle.
As far as storing the old chip is concerned, you don't have to worry about that. As I mentioned in Paul Watkins S2 chip thread:
John_W wrote:Paul,
I'm afraid it doesn't work like that. You don't end up with a spare old chip when you fit a Mountain chip.
The old chip is not independently removable but is contained in a housing which also contains the "limp home" circuitry. As such the old assembly is retained, and both it and the new Mountain chip are plugged into the adapter board such that the old chip (although present) is not electrically connected.
For a more lucid explanation see here.
The bottom line is that I'd go for the 9930-based Everest and adjust the CO pot.
Postby GeoffSmith » Thu 11.09.2008, 22:55
John_W wrote:The bottom line is that I'd go for the 9930-based Everest and adjust the CO pot.
Postby Exbury » Fri 12.09.2008, 14:57
Thanks for that! Hope ESM has one spare around, its good to be back and even better if i get back in the Lotus....anticipated MOT test date next week sometime!
Jason
Exbury
Postby ESM » Tue 16.09.2008, 17:48
I'm up to my elbows in chips...
ESM
Return to Upgrades
