MattDon wrote:Ive got 2 Elan ecu's one's an early 9929 and the other is a 9930, can i just swap the whole lot over (ie metal box with everything in)? the reason i ask is that i have two everest chips and ones a v4.2 9929 and the other is a v4.5 9930. cheers
I think that the 9929 and 9930 have completely different CO potentiometer calibration, so in theory, yes you can swap from one to the other by just changing the boxes over.
In practice, you'll probably need a gas analyser to measure the CO output before you do, and then to adjust the CO pot to bring it back to the original reading afterwards.
I've moved the question to here because Alan is more likely to see it and confirm the above answer.
