ailwyn wrote:I am assuming that as long as I'm keeping the peco then the front pipe/flex section is not required?
Gazza wrote:What's the final price?
Pre-cat $125
Jet-hot $35?
p/p ?
Gazza
nitroman wrote: If you are aleady Peco'd you don't need a front pipe. As the continuing banter over a combined PCE/Frontpipe, it would have to welded to the bottom of the PCE funnel. Better I think, for me to inquire into the shop making a front-pipe-stub encompassing the 3-bolt-flange, a short 90-degree-mandrell pipe, and another short-piece to get you straight & level. If you still have a stock, or any other 2" system, you are a candidate for this. I will enquire as to it's price this week.
Elanlover wrote:nitroman wrote: If you are aleady Peco'd you don't need a front pipe. As the continuing banter over a combined PCE/Frontpipe, it would have to welded to the bottom of the PCE funnel. Better I think, for me to inquire into the shop making a front-pipe-stub encompassing the 3-bolt-flange, a short 90-degree-mandrell pipe, and another short-piece to get you straight & level. If you still have a stock, or any other 2" system, you are a candidate for this. I will enquire as to it's price this week.
Matt, I've got a custom, 2.25" system which was mated to the old 2" just after the downpipe turns. A reducer was used and all was welded up together. So, I'm still connected to the OEM downpipe and there's no flex section at all.
I don't want to complicate things at all. I just can't help thinking that a welded pre-cat/downpipe combo is better than one which has a break in it connected by the flanges. Maybe its not a big deal at all and I profess little to no knowledge in this area. In a perfect world, I suppose it would be a one-piece PCE/downpipe pice I could mate to the system I have in place now.
Having said this, I suspect this may cause problems with the JH coating. If this one-piece terminated after the bend in the downpipe as just an open end that could be welded to the existing system could it even be JH coated? How could you weld the JH coated end to another SS section? Can you weld the coating? Would they leave a couple of inches at the end of the pipe uncoated so it could be welded?
More than just a few quesiotnsI could call JH if you like though if you think its worth while looking into or do we take a pass and go with the JH coated PCE and separate uncoated downpipe/flex portion?????
nitroman wrote:It's just too out of step with the design of the system, and counter to what everyone has. Of course it's easy to find someone who can weld; so, if anyone wants to weld it all together, it can surely be done.
On the prior page you requested I order you a flex-section, which I did. I am assuming you want both the PCE & front-pipe JH-coated, correct?
geoffsmith wrote: especially for a man who can afford AP's.
nitroman wrote:Yes. I'll have him weld on the flex then stop, as anyone can weld straight sections of pipe on.
nitroman wrote:Gentlemen in the UK; please select someone to receive the parts I am turning over to Her Majesty.
geoffsmith wrote:
2. ) Woody - Nottingham
6. ) Paul.P - Rutland
8. ) MattDon - Yorkshire
9. ) Geoff - Bristol
10) Ailwyn - Pontypridd
11) Gazza - Romford
Elanlover wrote:I'm now curious to know what people's experiecne has been (if any) with boost creep once the pre-cat is removed and with a 2.25" free fow exhaust installed. This would be specific to a Fed car which has 2 cats on it (and assumes you're still keeping the primary cat). From the few people I've heard from who have removed the pre-cat they don't seem to mention boost creep.
If the pipes are coming off to install all this new gear AND there's a good chance there'll be boost creep I might as well go all the way and port the wastegate although I'd prefer not to do that unless I have to.
Comments?
geoffsmith wrote: Mine crept after putting the Peco on. It didn't before with the stock exhaust, but there was nothing in either the pre-cat or main cat. I think you'd be as well to port it.
ailwyn wrote:Why not remove the pre-cat and see if you get boost creep, if you do then you can assess the options/impact.
If you do end up with boost creep it just means being careful about hard accelerations until you get it ported.
