by Kjeld » Mon 08.01.2007, 01:55
Maybe a little homework would have helped. Bought a set of plug wires for an Isuzu Impulse. Just tried to install them. For those of you who are not already laughing, the wires are not even close in length.
So, 2 questions. Where to get the correct wires and second, what is with the moulding at the end of the cam cover, where the wires are routed into the spark plug bay? rubbery black goo press in over the top of the wires to seal them against the plug bay cover. Is that a factory technique, or was the person that last changed the wires just a tad anal retentive? Pretty sloppy.
Ready to sell...... I think.
Kjeld
by jabrown39 » Mon 08.01.2007, 05:56
Hope you had a great brunch on Saturday.
Second Question: Mine has no junk. It is simply an open slot which the wires exit. Don't know if this is standard but would pick mine over your set up. There is no reason to seal the area dust free, but looks better with the cover and the deep socket wells are better left without debris falling in.
First question: I bought the magnecor wires because I have more money than sense. They fit right, are no longer the weakest link in the system, and someone else worked out any problems before I got my fat fingers on it. Hunt on here for part number cross references for cheaper options. Doug has written alot on the magnecour and the debate rages on. I have never been unhappy with mine.
jabrown39
- Tinkerer
by Sy V » Mon 08.01.2007, 09:12
There should be a plastic clip with 4 apertures that fits on a pin into the cam cover. The black gunk is somebody's botch job.
- LEC Godfather
by Jamie » Tue 09.01.2007, 03:15
Adding to Sly's comment, in case you don't understand, the spark plug cables clip into the apertures to hold the wires in place when going into the spark plug area of the head.
As for purchasing the wire, I purchased mine through
http://www.apexperformance.net. For some reason, they do not show a listing for Lotus. However, my invoice dated back in March 2005 show the following information: Magnecor Wires - 45286 - 8.5mm for 1991 Lotus Elan. The cost was: $91.68
On more thing, when installing the wire make sure to use electrical grease on the end of the plugs. For some reason, the plugs slightly corrode and like to fuse to the wires. If you don't do this, about 12k ~ 15k later when you change your plugs, you'll find yourself pulling the wire and having part of the wire that clips to your plug stock to the plug; thus, pretty much a ruined wire.
Jamie
by Doug » Tue 09.01.2007, 08:39
Jamie wrote:On more thing, when installing the wire make sure to use electrical grease on the end of the plugs. For some reason, the plugs slightly corrode and like to fuse to the wires. If you don't do this, about 12k ~ 15k later when you change your plugs, you'll find yourself pulling the wire and having part of the wire that clips to your plug stock to the plug; thus, pretty much a ruined wire.
- LEC Founder
by ailwyn » Wed 10.01.2007, 00:09
Jamie wrote:Adding to Sly's comment,
ailwyn
- Forum Member
by Sy V » Wed 10.01.2007, 09:22
Yes, it didn't go un-noticed!
- LEC Godfather
by Enright » Wed 10.01.2007, 09:50
Sly's a very observant old fox you know!
Edit: Oops, probably ought to be a bit more careful where the moderators are concerned. Don't want to jeopardise my status!!!
Neil
- Modificator
by GeoffSmith » Wed 10.01.2007, 13:53
Enright13 wrote:Don't want to jeopardise my status!!!
As if he would!
- Kitty Fiddler
by Enright » Wed 10.01.2007, 14:56
Thanks Captain sodding Mainwaring!
Well THAT will certainly reduce my posting rate...
Neil
- Modificator
by GeoffSmith » Wed 10.01.2007, 15:28
Gotcha!
Mr Wham would be proud of me.
- Kitty Fiddler
by dapinky » Wed 10.01.2007, 16:44
Don't tell 'em your name, Neil!
- LEC Administrator
by GeoffSmith » Wed 10.01.2007, 22:24
Enright13 wrote:Thanks Captain sodding Mainwaring!
- Kitty Fiddler
by algirdas » Thu 11.01.2007, 01:17
Dear Geoff:
Who is that in the picture you posted? Sure looks familiar. . . Colonel Klink?
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
by algirdas » Thu 11.01.2007, 01:21
Dear Geoff:
No sooner did I post the other message did I figure it out. Its Sergeant Schultz! I did not know that Hogan's Heroes was that popular over there.
Sincerely,
Algirdas
PS Initially I thought it was Elton John.
algirdas
by Jamie » Thu 11.01.2007, 03:04
Ops...Sorry for my typo Sy. But, it seems people had enjoyed it lol
Anyhow, I hope Kjeld got his wire problem solved.
Jamie
by nitroman » Wed 24.08.2011, 21:22
Kjeld wrote:So, 2 questions. Where to get the correct wires?
http://www.kingsbornewires.com/product. ... egoryId=41Only $31.75, comparitively one of the best deals we M100 misfits get!
nitroman
by Fourdoorcat » Thu 06.09.2012, 05:27
I installed some Robie Robot ignition cables over the weekend. It has probably been written before: make certain that you dress the wires away from the shift lever mechanism so it doesn't rub on the cables.
"Never ascribe to malice that which can be perfectly explained by stupidity"
Fourdoorcat
by epipete » Tue 11.09.2012, 11:26
Checked out the Kingsborne web site and, yep, their cables are a great price at $36.75 US and was about to order, but I baulked at the $191.50 for postage, apparently they offer no alternative other than UPS Saver (!).
Incidentally, would these have fitted given some of the previous threads about their length being incorrect?
Ah well back to good old rip off Britain @ £80.00 a set I guess.
Pete
