Hood/Window Adjustments
Post the Good, the Bad, and the Ugly Lotus service experiences here.
Postby ailwyn » Thu 07.12.2006, 15:43
The swimming pool in the passenger footwell is all I need as a final push to try and get someone to sort my water ingress issues.
I realise this will probably end up coming down to how soon either can fit me in, but here goes:
Matty's vs SJs - anyone have any experience of either or both when it comes to A-post seal replacement, hood realignment or window adjustment?
Distance will be about the same to either, so no worries from me on that front, but I would rather get this all sorted in one go rather than a few attempts.
Also anyone have any idea on how long the above might take (assuming both hood and windows need adjusting)?
Ailwyn
ailwyn
Postby Gazza » Thu 07.12.2006, 16:58
Ailwyn
When Sinclaires did the a-post seals on my old Elan, they advised me to change the metal carriers they sit in as they were only £25 each and would save alot of time and money trying to clean the old ones up to get a good fitting.
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Sy V » Thu 07.12.2006, 19:13
SJs.
You all know that Paul Matty is a mate of mine. I have my reasons for not recommending them in this dept.
LEC Godfather
Postby ailwyn » Fri 08.12.2006, 00:56
Gary,
Thanks for the tip, I'll add them to my shopping list :)
Sy,
Thanks for the advice, will call SJs tomorrow and get the car booked in.
Ailwyn
ailwyn
Postby ailwyn » Fri 08.12.2006, 12:18
:shock: Just been on the phone to SJs, they can fit me in.... in June!!
Anyone have any alternatives they'd recommend I try for maybe a slightly earlier appointment?
Ailwyn
ailwyn
Postby Monty » Fri 08.12.2006, 12:27
Yeah, fit them yourself :-D
When Dico had his windscreen replaced Chris Neils (Lotus dealer) didn`t do a perfect job on the A pillar seals :roll:
Could cost u a small fortune as i would imagine adjusting the windows etc would be time consuming and i bet they won`t garantee that it won`t leak. If it does leak are u going to drive all the way back?
Postby GeoffSmith » Fri 08.12.2006, 17:22
ailwyn wrote:Anyone have any alternatives they'd recommend I try for maybe a slightly earlier appointment?
We could bring some tools on Monday - sledgehammer, cold chisel and crowbar should fix it! :-D
Postby paza1 » Sat 10.03.2007, 14:49
Monty,
What problem did Dico have with Chris Neils? Got me woried coz when the seals finally become available, they will be doing mine :shock:
Mark
Silver 1992 SE Turbo.
paza1
Postby Dico » Sat 10.03.2007, 17:32
pazza, best hearing it from the horses mouth :wink: just wait till you see my teeth at Donny :-D
CN were not all that bad, just not perfect. Probably give them 8ish out of 10.
They managed to snap one of the seals at the top were it meets the top edge.If you look there are two plug holes and this is a weak point if your a bit heavy handed.
The sealant on the edges wasn't perfect but wasn't too bad I suppose. I could of got it better.
The other 'minor' fault was the black flexible strip which runs paralel with the A post seal, were it finishes on the bottom edge. On the passenger side it had been cut at an angle, which was correct, the drivers side had been cut slightly higher and straight across causing it to stick up a little.
Makes sense to me :)
In my opinion your always going to take more care if you do it yourself, and I wouldn't have expected anyone else to carry out a better job really.
I think the cost was somwhere in the region of £1200 - £1300 :shock:
Postby Paul.P » Sat 10.03.2007, 19:15
Ailwyn, don't know what the distance is to GST in Newmarket from you, but i can guarantee you a 1st class job. I agree with Monty & Dico, that if you are competent enough to do it yourself, then you can save a lot of money, but that option ain't open to all of us !, also do you really want to risk £300 worth of seals ?
Postby paza1 » Sat 10.03.2007, 20:17
Thanks for the info, I will keep a close eye on the job they do.
See you at Donni
Mark
paza1
Postby paza1 » Sat 10.03.2007, 20:25
Ailwyn,
I have been fiddling with my roof seals today and discovered (unless people already knew this) that you can get a good seal between side window glass and seal by fitting extra foam (or in my case aerial coax :D ) behind the seal, between it and the carrier. I found some foam already tucked in there, so it was either done at the factory or by previous owner.
Mark
paza1
Return to Service
