Weight of the S1 (non-turbo) wheels
Postby stu » Tue 20.03.2007, 22:04
Does anyone happen to know the weight of the S1 wheels?
I have found these at Halfrauds and I'm thinking about purchasing them, in silver.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_254141_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_70552_crumb_33967-55061_parentcategoryrn_70552
Stu
"Racing is life. Anything before or after is just waiting"
Steve McQueen
stu
Postby Specky » Tue 20.03.2007, 22:09
Two words.....
Off set.. :shock:
Postby Enright » Tue 20.03.2007, 22:09
Just put one on my scales - a stone (6kg).
Postby stu » Tue 20.03.2007, 22:13
Dave_Speck wrote:Two words.....
Off set.. :shock:
Lol - I'm looking to order the 53mm offset, best so far.
Steve McQueen
stu
Postby Doug » Tue 20.03.2007, 22:26
well I like the wheel and I am definitely impressed if they have a 53mm offset because that is about the biggest I have heard of for an aftermarket wheel. The stockers are +60mm as you likely know. Many people have defaulted to the common +40mm offset and no one has had definite ill effects from it.
you can argue all you want about the spacings and handling, etc, but they sound like a great match for the Elan.
ask them about mounting = you may need a hubcentric ring adapter from the wheel center bore to the Elan hub, you will likely need new wheel bolts or you could convert the Elan (like mine was) to using studs in the hub and then new nuts that go onto them over the wheel (like most cars in the world use).
Postby stu » Tue 20.03.2007, 22:35
Great, thanks for the advice. I'll keep you up dated with what happens in the next few days!!
Stu :-D
Steve McQueen
stu
Postby stu » Wed 21.03.2007, 22:55
Doug wrote:well I like the wheel and I am definitely impressed if they have a 53mm offset because that is about the biggest I have heard of for an aftermarket wheel. The stockers are +60mm as you likely know. Many people have defaulted to the common +40mm offset and no one has had definite ill effects from it.
I have spoken to the guy at Rim Stock and he said that the maximum is 45mm offset which they can do...will this be okay, I'm sure it will be but I just wanted to double check!?
He also mentioned a possible discount for all if anyone else wanted alloys?! If you do then please let me know and I will sort it out.
Cheers Stu
Steve McQueen
stu
Postby Doug » Thu 22.03.2007, 00:10
+45 is fine. As long as you know they are not the same as the OE and that they should not cause any problem you will be fine. They will protrude +15mm further out from the centerline, but the way the Elan looks, it should improve its appearance. The wheels I settled on were +47mm. I think you wouls have to do a custom job to get full OE spec wheels!
Return to Wheels and Tyres
