ESM Chips - Information & Help
Postby ESM » Thu 21.06.2007, 18:08
There is an update chip item on my site. I'm too lazy to organise an annual subscription type thing.
ESM
Postby nitroman » Thu 21.06.2007, 21:13
Please remit 10-GBP per annum until such time as correspondence is returned "deceased". Seems simple enough.
"Upon receipt you will be supplied with a new chip good for another 365 startups before it begins to randomly ignore input from various sensors. Have a pleasant journey!"
nitroman
Postby Siegreen » Sat 30.06.2007, 15:54
Alan,
Recieved my Everest chip in the post today and fitted in about 20 mins, dead easy instructions to follow.
Took the car out for a spin and although the rain is coming down, so just took it nice and steady there is a great improvement, very nice progressive boost all the way up. Will have to have a go when the road is dry.
BIG BIG Smiles :smt040 :smt040 :smt040 all round, your a star.
:clap: :clap:
Many thanks.
Si
I fart in your general direction! You mother was a hamster and your father smelt of elderberries!"
Azure Blue S2 No. 452
Siegreen
Postby Russc » Sat 30.06.2007, 18:41
Mine switcher turned up as well this morning, can`t wait to fit it and have a play :)
Russc
Postby ESM » Sun 01.07.2007, 12:55
Glad to hear they arrived - I'm always interested in feedback so let me know what you think once you've had a bit of time to get used to it.
ESM
Postby surfboardfiller » Sun 01.07.2007, 21:31
I installed my Everest last weekend but no difference. turbo stops at 0.5 bar
I disconnected the battery and re connected but no difference.
If I plug my laptop into the ECU can I tell if the Everest is working and something else is blocking the boost?
surfboardfiller
Postby ailwyn » Sun 01.07.2007, 22:19
surferphil wrote:If I plug my laptop into the ECU can I tell if the Everest is working and something else is blocking the boost?
Probably not, but you will be able to see how much boost you are actually getting.
Will anybody ever learn not to trust the gauge :roll: :-D
ailwyn
Postby GeoffSmith » Sun 01.07.2007, 22:54
ailwyn wrote:Will anybody ever learn not to trust the gauge
Lesson for the day - the gauge is NOT accurate.
Postby Monty » Sun 01.07.2007, 23:16
Well my gauge is accurate :wink:
Postby surfboardfiller » Sun 01.07.2007, 23:26
Bloody useless then isn't it, I feel an upgrade coming on... A boost guage that measures boost pressure! :wink:
The car doesn't seem much quicker, I guess I'll have to wait for the next scoobydoo to test it. Or maybe I have a fault in the engine!?
Does the Ailwyn HUD display boost pressure?
surfboardfiller
Postby ratman » Mon 02.07.2007, 07:32
My gauge is working only in acceleration. When the car is going with constant throttle it signs 0. I think that it’s not very normal!
Have I to check if it is loosing precious pressure???
Lotus Elan S2 n°538
ratman
Postby ailwyn » Mon 02.07.2007, 08:37
surferphil wrote:Does the Ailwyn HUD display boost pressure?
Just MPH & RPM.
Elanscan will give you an accurate boost reading.
Ailwyn
ailwyn
Postby Russc » Mon 02.07.2007, 10:17
surferphil wrote:The car doesn't seem much quicker, I guess I'll have to wait for the next scoobydoo to test it. Or maybe I have a fault in the engine!?
Just sent you a PM, if you haven`t got elanscan and are near me feel free to come down and plug it in.
Well worth getting a lead though if you haven`t got one :)
Russc
Postby John_W » Mon 02.07.2007, 12:43
ratman wrote:My gauge is working only in acceleration. When the car is going with constant throttle it signs 0. I think that it’s not very normal!
Ratman,
That is normal behaviour. The boost is controlled by the accelerator pedal (or rather the ECU and the BSV and wastegate), and is only generated when you need it (like accelerating with 100% throttle or going uphill with the throttle pedal pressed down more than usual).
If it gave boost at all times, you would quickly suffer from overboost.
Postby ratman » Mon 02.07.2007, 15:43
no, I don't think so. the boost is on when you are over 2000 rpm or something like this. If you said that the boost is only in acceleration, it means that it is NA when the car is in constant throttle....
Lotus Elan S2 n°538
ratman
Postby paulwatkins » Mon 02.07.2007, 16:25
surferphil wrote:I installed my Everest last weekend but no difference. turbo stops at 0.5 bar
A daft question, but was the engine up to operating temperature?
I believe the boost is regulated to 0.5bar until it gets to op. temp.
paulwatkins
Postby surfboardfiller » Mon 02.07.2007, 17:11
Yes, the engine was warm, but maybe the thermostat is wrong; it's been running cold for a while (until I stop in traffic).
I do have a Jester Smith USB Cable, so I could sit a mate in the passenger seat to watch the boost pressure on Elanscan :-D
Cheers!
surfboardfiller
Postby paulwatkins » Mon 02.07.2007, 17:43
Phil,
let the engine run (at standstill) until the fans cycle (the temp gauge should read about 3/4 when the fans kick in), to make sure the engine is at operating temp and then give it a trial.
Even if your boost gauge is not accurate, you should feel a noticable difference!
paulwatkins
Postby Candles » Mon 02.07.2007, 18:00
ratman wrote:If you said that the boost is only in acceleration, it means that it is NA when the car is in constant throttle....
Almost 100% correct Ratman, like an NA, only with the restriction of the turbo in the inlet when you don't have the throttle very wide open. This is because the amount of gas flowing out of the engine is insufficient to create boost.
Candles
Postby ESM » Mon 02.07.2007, 21:10
Ratman, you should see boost only when on high throttle - the turbo needs high flow on the exhaust side and low resistance on the intake side to push the intake pressure above ambient pressure (as others have already said).
Phil, check your BCFV is connected (clear topped thing attached to the side of the air cleaner box) and that the fuse is ok.
ESM
Return to Upgrades
