Pads
Pads
Postby Monty » Mon 13.08.2007, 16:21
Thought i`d start this thread up for alternative pads for the stock system for future reference. Hopefully others will post other Alternative part numbers and links
Rear Pads
EBC Standard
Part No: DP978
Rear Pads " Both Wheels "
Details
Standard Replacement Pad
Original Replacement Pad Set Tested To EU R90 Regulations.
"As Good as Original Pad or Better."
List Price: £29.34
Price: £26.41 (£31.03 Inc. VAT)
Rear Pads
EBC Greenstuff
Part No: DP2978
Details
Greenstuff Pads Upgrade
List Price: £42.50
Price: £38.25 (£44.94 Inc. VAT)
www.brakes4u.co.uk
Postby Monty » Mon 13.08.2007, 16:28
Fronts
www.brakes4u.co.uk/ also do the Fronts
Part No: DP325
Front Pads " Both Wheels "
Details
List Price: £8.42
Price: £7.58 (£8.90 Inc. VAT)
Part No: DP2325
Details
List Price: £33.03
Price: £29.73 (£34.93 Inc. VAT)
www.brakes4u.co.uk/default.asp have the Elan listed and do other parts ie. Disc etc
Postby rip » Tue 14.08.2007, 09:45
The front pads are the same as a Mark 1 1300 Astra, or an early Nova SR, but I don't know the part numbers. I think from memory that Ferodo's pattern number is 172.
From what I have read on here, performance upgrades are a good idea. I have gone for the Ferodo 2500 option, but have yet to fit them.
Postby rip » Mon 20.08.2007, 09:10
rip wrote:I think from memory that Ferodo's pattern number is 172.
Poor memory. That should be 173.
Postby rip » Sat 29.09.2007, 19:13
How about some alternatives for the rear pads? I don't want to upset the balance too much but I have bought better pads for the front so something with a little more bite at the rear would be welcome.
I would rather avoid Greenstuffs. I want to stop with cold brakes too.
Postby JOSLER » Sun 30.09.2007, 09:08
rip wrote:How about some alternatives for the rear pads? I don't want to upset the balance too much but I have bought better pads for the front so something with a little more bite at the rear would be welcome.
I have the Greenstuffs and there crap from cold.And sometimes when they are warm you can get a bit out of shape when braking.I here the blue ceramic ones are realy good. :wink:
1991 Calypso Red SE
JOSLER
Postby rip » Sun 30.09.2007, 20:32
I think you are talking about fronts, or pads in general.
The only rears I can find are stock or greenstuffs. I would rather avoid both of them.
Postby rip » Fri 05.10.2007, 09:28
I have now found other alternatives for rears
EBC Redstuff DP3978C
EBC Yellowstuff DP4978R
Powerstop Evolution PWR-16-377
978 is the size code to look for with EBC, 377 is the size code for Powerstop.
Available from the US only :( . For others, look up Chevrolet Lumina. The 1990 2.5 appears to use the same rear pads. You get much more choice than if you search for Lotus Elan.
US brake pad searches
Postby tweetdriver63 » Fri 19.10.2007, 17:14
In the US, the rear pads are the same as on 88-93 Buick Regal, 90-94 Chevy Lumina, 88-93 Pontiac Grand Prix, and 89-93 Olds Cutlass Supreme (I would personally use the Cutlass Supreme as the search query since all versions use the same rear pads. On some of the others, different versions/trim levels may have different brake setups.)
For the front pads, search using the 88-89 Pontiac Fiero.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby tweetdriver63 » Fri 19.10.2007, 17:17
rip wrote:I have now found other alternatives for rears
I've found that the 377 size code is true for most brands (in the US anyway). Raybestos, Durastop, Wearever, etc, all use it.
For the fronts, the EBC size code is 325, most other brands, it's 378.
'91 Elan SE
tweetdriver63
Postby Oliver » Thu 01.11.2007, 18:05
No one will probably want them but for the record:
86 71 010 061 - (Motrio) front pads from Renault dealers. Standard kevlar -
good O.E. quality and VERY cheap (£15)
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby rip » Fri 02.11.2007, 16:52
Oliver wrote:No one will probably want them but for the record:
Good to know. It may come in useful at some time. If you could find out what Renault they are for, it may be possible to cross-reference them for some more alternatives.
Postby Oliver » Mon 12.11.2007, 21:29
These pads are manufactured by Renault, and sold under their `all makes` brand, Motrio. These particular pads are actually listed as an application for:
Opel Ascona, Vectra, Corsa, and Astra 2.0i.
They are high quality, just OE spec and not anything trick (and very cheap). See the picture below ----
I`ve just ordered a pair of front disks, again a Vauxhall / Opel application, i`m sure they`re correct for the Elan and again are high quality / cheap. If they are correct i`ll post the part nos.
I`ve got a huge Motrio book so i can cross reference numbers back and forward.
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby philip_sloper » Tue 13.11.2007, 17:39
In my opinion the best front pads available are Pagid Blue:
PAGID part number is E9521 (RS4-2)
UK suppliers are:
Performance Braking – 01600 713117
Kelvedon Motors - 01775 725457
GST Performance - 01638 742946
Grand Prix Racewear – 01327 855585
Questmead - 08707 450584
Motorsport World - 01357 529 291
Importer is Competition Braking Products -01748 821500
Price around £110 plus VAT - much more expensive than anything else but much much better too. On the rear mine work fine with EBC Blackstuff, ref DP978
See also
http://lotuselancentral.com/forum/viewt ... 47&start=0
philip_sloper
Postby dermotbell » Tue 04.12.2007, 23:54
philip_sloper wrote:In my opinion the best front pads available are Pagid Blue:
UK suppliers are:
Concur with PAGID pads. Best option without upgrading caliper.
Dermot Bell
dermotbell
Postby wonderfish » Sat 19.04.2008, 20:50
Looking at the spares manual at my local parts shop, it seems that the Elan shares its rear pads with an Oldsmobile, although I'm not sure which model. They still come in at £45.00 though
I need to go back tomorrow for some new rolled pins for my front calipers, so I will find out then (silly me for thinking that they might come with the reconditioned calipers I bought from SJ Sports Cars on Friday, but they get a thumbs up for despatching after a phone call at 4pm on a Friday for a Saturday delivery).
And whilst I'm at it with the big thumbs, extra big thumbs for Sy for uploading every single manual possible for the Lotus Elan, it's been a big help after my MOT failure (on Friday morning, can you spot a pattern here?).
I won't get started on whoever bodged my front brakes before I owned the car - half worn green stuff pads on the right, completely worn stock pads on left were just the start of it...
wonderfish
Re: Pads
Postby tweetdriver63 » Wed 24.09.2008, 01:14
Fronts, Mintex Red Box pads, number MDB1141.
'91 Elan SE
tweetdriver63
Re: Pads
Postby dapinky » Wed 24.09.2008, 08:37
tweetdriver63 wrote:Fronts, Mintex Red Box pads, number MDB1141.
£63.87 at Merlin Motorsports (Castle Combe circuit) - cheaper than the Pagids by a fair amount - but a comparison would be nice - has anyone tried both????
Re: Pads
Postby tweetdriver63 » Wed 24.09.2008, 12:55
ebay for a total of $14.19 US :-D
1 more set available, worldwide shipping
I don't know how they compare to the Pagids, but they clearly show me that the Wagner Thermoquiets I had were shite!
'91 Elan SE
tweetdriver63
Re:
Postby donsladek » Sat 07.02.2009, 16:16
UK suppliers are:
See also
I recently bought a set in the US from Velocityspot.com in Santa Barbara CA for ~$153 USD. However these are no longer listed on their site - maybe I got their last set?
Don Sladek
Calypso Red '91 #37594
donsladek
