Front rubber skirt.
Front rubber skirt.
Postby Martin R » Sun 18.11.2007, 19:39
Ive started the winter maintenance. It took me about 1.30 hours to remove the rusty screws from the front rubber skirt. Im going to replace them with new clips and 5mm hex headed S / S set screws. The rubber skirt is looking a bit past its best. Can you still buy them ? Also is a dealer the only source if you can. Ive had a search but cant find the information TIA.
2 Lotus and ones got to go :-(
Martin R
Postby clemo » Sun 18.11.2007, 19:45
walker rubbers sell them direct.. about £20 if i remember rightly
the crapy plastic bits have been known to be replaced with mechano strips..!!
clemo
Postby Martin R » Sun 18.11.2007, 19:52
Ta very much. I presume this is the one ?
http://www.walker-rubber.co.uk/s3/Automotive.html
Im going to use these hopefully.
http://www.eliseparts.com/shop/index.ph ... cts_id=444
Martin R
Postby clemo » Sun 18.11.2007, 19:55
thats the ones..
clemo
Postby DeeAitch » Sun 18.11.2007, 20:14
DeeAitch
Postby johnny » Mon 26.11.2007, 21:51
I did mine at work, hour & half.... not me, 4 hours, after two hours i was thinking, why did i start this :evil:
It was 20 pound, got mine from SJ. Comes all bent and white looking.
Once its on with a tin of back 2 black, looks good.
Hey- there's only on f in Geof Smith.. U crack me up. Poor old Dad..
johnny
Postby Dico » Mon 26.11.2007, 22:00
Its a bit cheaper if you buy direct from Walker rubbers. If you can find the link :-)
johnny wrote:I did mine at work, hour & half.... not me, 4 hours, after two hours i was thinking, why did i start this :evil:
:shock: :? :-D
Postby clemo » Mon 26.11.2007, 22:04
plus don't back to black it as it will just run off...
get a old cloth with thinners on it...
cleans up a beaut...
also do your tyres with thinners too.
much nicer than cockpit slime...
clemo
Postby GeoffSmith » Mon 26.11.2007, 22:10
Dico wrote:Its a bit cheaper if you buy direct from Walker rubbers. If you can find the link :-)
One day, someone's going to have to teach you lot how to use the search facility! :roll:
CLICK >>>HERE<<<
Postby clemo » Mon 26.11.2007, 22:32
geoff ..
i wish it was obvious..
was it lost on the old LECsite...
oh think ive found it ..
right no thats not it
look here look here
nope
try again
Code: Select all
thats it ....[img]
wow i have just noticed if you hover the arrow over the stuff above it tells you what it does.. well sort of...
but i still dont understand it..
geoff???[/img]
will ask questions up on litrature..
if i cud speel it
clemo
Postby Steve A » Tue 27.11.2007, 00:44
:D Look in the "Part Cross Reference section", all the latest up todate info 8)
