by Specky » Mon 28.01.2008, 11:51
Just a quicky...
How do you remove the left and right heater vents..(UK)
I can see the two screw threads and the riveted brackets..
by Dave Eds » Mon 28.01.2008, 16:46
Dave there is a metal bar about 2" long riveted to the back of the dash.
The vents are screwed in by a small screw (into a locking nut) at the other end of the bar accessed through the vent itself. Tricky if not impossible to do unless dash board is out. Problem is that the vent is briitle and the hole for the screw is close to the edge of the vent therefore the plastic vent can snap.
by Specky » Mon 28.01.2008, 18:33
Dave Eds wrote:Dave there is a metal bar about 2" long riveted to the back of the dash.
Not entirely sure what you mean...
I'll take a photo or two and it might help..
I take it there's three screws...
by Dave Eds » Mon 28.01.2008, 18:37
There's a dash board in my garage with your yellow bumper if you care to take a look
by Specky » Mon 28.01.2008, 21:33
Dave,
Fill in the gaps on how to get this bad boy out please..
by Dave Eds » Mon 28.01.2008, 22:48
Bracket to the left of your pic has 2 screw ends pointing down. I think I used pliers to "unbolt" the retaining nuts - bit of a cop out as I only wanted to get the vents out and wasn't worried about the bracket. You could drill out the rivets if you were a little bit smallerer
by Specky » Mon 28.01.2008, 23:02
can you pop out the lower vent from it's housing?
by Specky » Mon 28.01.2008, 23:31
So It's a right angle screwdriver through the vents...
or cut a slot in the back and unscrew that way..
Return to Interior
