CAS O ring
CAS O ring
Postby GeoffSmith » Fri 01.02.2008, 17:37
Mine appears to be weeping. SJ's want £4.31+VAT! :shock:
Can anyone confirm whether it is a special profile or just a standard circular profile ring?
Postby Candles » Fri 01.02.2008, 18:07
Just a standard O-ring. Presumably someone like you has a massive selection in their workshop? I could go out and measure my spare but I'd get my hands all oily, it's freezing and I'm about to go and see the in-laws.... Sorry :wink:!
Candles.
Candles
Postby dapinky » Fri 01.02.2008, 18:11
Its the big one from a multi-pack i got at Halfrauds!
(99p)
A smear of sillycone just to make sure - no leaks in the past year!
Postby GeoffSmith » Fri 01.02.2008, 18:12
Thanks mate :smt097 but don't worry because the turbo and exhaust are on the workbench, so it's some way down the to-do list :-D
[Edit: that was aimed at Candles not the ever helpful Pinky!]
If someone could measure it for me (OD and thickness will do) in the next few days, I'd appreciate it. It must be one of these then:
Postby John_W » Sat 02.02.2008, 00:47
Geoff,
I've got a busy weekend ahead, so won't be able to dig out my spare O-ring from SJ, but meanwhile have a look here.
Postby Specky » Sat 02.02.2008, 01:05
So the rumours are true.. :shock:
Can I do my blown a seal gag... :smt026
I'll get me coat instead... :roll:
Postby GeoffSmith » Sat 02.02.2008, 01:53
Thanks John. Looks about 23.7mm (ID) x 3.5mm :smt023 CONFIRMED AS CORRECT SIZE
No, can you tell me where I can get stainless M10 x 1.25 serrated flange nuts from? :D
CAS oil seal.jpg (49.27 KiB) Viewed 6713 times
Postby nitroman » Sat 02.02.2008, 08:09
nitroman
Postby Dico » Sat 02.02.2008, 09:04
Where are you wanting to use them Geoff?
Postby GeoffSmith » Sat 02.02.2008, 14:48
Unfortunately , I think they're 1.5mm (not 1.25mm) thread and there are only 8 (I need 9) of them Matt.
Dico wrote:Where are you wanting to use them Geoff?
The O rings are on the CAS you daft bugger. :roll: Oh, the nuts! I'll that for you to work out as I've given you enough information. :D
Postby nitroman » Sat 02.02.2008, 19:02
He's using them on the exhaust manifold & to bolt the turbo assembly down.
I bought them in Atlanta from a local place. Maybe I still have the receipt.
nitroman
Postby nitroman » Sat 02.02.2008, 19:22
http://mmsacc-stainless.com/metric/html ... shers.html
Who's your buddy? Who's your pal? That's right. Here ya go mate; on the left down towards the bottom. MMS is a great-big warehouse full of threaded stainless bits in Atlanta.
Bolt Depot has them in 8.8 steel, but I've had these on for almost 2 years now with no problems. They are such a large-size nut, it would take a massive force to deter them from their job of securing things.
1.5 is the normal pitch for size M10. They have those too but be sure that's what you want.
Posterity photo. Yes I know you want serated flange... they have them too. And they're all stainless to boot.
nitroman
Postby GeoffSmith » Sat 02.02.2008, 21:02
Thanks Matt.
I've found I can source the four turbo to wastegate manifold bolts and nuts in stainless at the same price that Lotus want for the rusty stuff! It's also interesting to compare prices: UK @ 1.79GBP or US @ 1.19USD - you don't appreciate how lucky you are over there!
Anyway, I wonder what Davey Knox can get them for. :roll:
Geoff
PS with the rate at which Matt's hijacking threads (CAS oil seal to stainless fixings and Bill's Isuzu intake pipe to aftermarket wheels) he'll soon be an honourary member of the East Midlands crew. :smt044
Postby GeoffSmith » Sun 03.02.2008, 21:22
geoffsmith wrote:Looks about 23.7mm (ID) x 3.5mm
It checks out against my worn one, but confirmation against a new one would still be good.
Now, how do I get the rear (inlet cam) end seal plug out, because that's where the leak is? :cry:
Postby John_W » Sun 03.02.2008, 21:41
Geoff,
To get to mine, I had to remove the bracket which is obstructing access (careful when re-bolting it on, as it's easy to strip the thread in the alloy), then just persevere with a 10mm (I think) spanner on the single bolt which holds it on.
When I removed mine, the O-ring was flattened a bit, but the main surprise was the amount of crusty black crap inside the blanking plug. I presume it was toasted oil residue, but I hope not as I'd hate to think the oilways look like that. I scraped it out and cleaned things up.
I used some sealant (outboard of the O-ring) just to make sure I'd cured the leaks, as I wasn't impressed by the single-bolt fixing of the plug (I think it gives to much possibility for flexing). Refitting the bolt which holds the plastic plug was a sod. I dropped it three times and most of the time was spent finding the ruddy thing again. I suggest putting a turn of fuse wire round it just to act as a safety-chain until you get it properly located and started in its thread, then you can just pull the fuse wire to unwind it off.
Good luck,
Postby GeoffSmith » Sat 16.02.2008, 22:26
I thought I could get to the little devil by disconnecting everything and moving the wiring harness down but no such luck. :cry: It's not too bad to remove the two bolts as John says and then it's quite easy.
Well, no the wonder it was weeping. It's obviously happened before and someone has plastered what appears to be studlock or similar all over it. In fact I think they've even gone to the bother of removing it as there was plenty past the O ring - if you've gone to that much trouble, why not do the job right! :evil:
I didn't think there was an O ring to start with, as it was encased in hardened gunk. Eventually cleaned it up and removed a very square and brittle O ring which has now been replaced along with the CAS one. :D
Postby Paul.P » Sat 16.02.2008, 22:39
Good job Geoff !
Postby Specky » Sat 16.02.2008, 22:41
I was meant to do that today as well...
Had to go to work on the carbon fibre troop provider...
So it tomorrows job..
Geoff are you saying just undo the two bolts on the bracket and that will give you access to the one bolt on the blank..
Postby Specky » Sat 16.02.2008, 22:43
I'll take some photos for the wiki too..
Postby GeoffSmith » Sat 16.02.2008, 23:21
Remove the two (12mm A/F) [blue] - I removed the two hoses [red] to get at the little sucker (12mm A/F) [yellow].
