Glove box lock (again)
Postby paza1 » Tue 23.08.2005, 00:24
My glovebox lock barrel has fallen out in the locked position (saw the other post too late, doh!). Has anyone else had experience of replacing it? I could really do with an in depth procedure (with pictures if poss) as I am nervous about taking a hacksaw to something I can't see or visualize. Also, am I correct in assuming that SJS supply (A082U7985F) a new catch, not the lock? Any help greatly appreciated.
Silver 1992 SE Turbo.
paza1
Postby Matt RI » Tue 23.08.2005, 15:36
My parts manual has been borrowed and is out of my hands at the moment- but IIRC, you are correct that SJS supplies a non-locking latch (the plastic bit, but solid w/o a lock in the center) as the locks are quite prone to sticking in the locked position... My Elan came w/o a glovebox lock, I got lucky in finding a used replacement with an original lock (at least until it breaks or I replace it with a more reliable version).
Not sure how to fix the lock itself. Sorry!
Matt RI
Glovebox lock (again)
Postby paza1 » Fri 26.08.2005, 18:47
Thanks for the reply Matt. I have now fitted a non-locking replacement. No hacksaw used, just removed the already loose barrel, tugged on the catch, it detached easily, then the glovebox opened :!: :D
paza1
Postby Matt RI » Mon 29.08.2005, 15:55
Nice!
I'll keep that in mind when mine goes :wink:
Glad that you are set with the new latch. If you really want a locking mechanism for your glove box, and still have the old barrel, you might have some luck taking it to a locksmith and getting a new lock fitted. IIRC, Darren had some success with that a while back? Something I have been meaning to look into myself.
Matt RI
Postby paza1 » Tue 30.08.2005, 00:33
I would prefer a locking glovebox but I am now a bit wary of the latch mechanism (which I have still got). I think the old catch pivot pin was previously broken and bodged into position. I will keep all the bits and take your advice when I have summoned up the courage to look at it again. Thanks again.
paza1
Postby GeoffSmith » Wed 13.02.2008, 18:49
Did you ever summon up the courage? :wink:
Guess what I'm playing with at the moment! :evil:
Postby paza1 » Wed 13.02.2008, 19:24
Hi Geoff,
Decided it wasn't worth the hassle and worry of it going again so fitted none locking one....might investigate if anyone on here has come up with a better barrel design someday :roll:
Hope you get it sorted, would be interested in how you get on...
Busy with new brake lines all round and just finished adjusting shut lines on light pods...what a fiddle and faff
Did you get anywhere with the USB converter?
Mark
paza1
Postby paza1 » Thu 14.02.2008, 01:22
Answered elsewhere...nice one :smt023
Mark
paza1
Postby GeoffSmith » Thu 14.02.2008, 09:13
Mark
Glad to see you're paying attention! :-D
There's a collation of glovebox links and more on the glovebox lock dissection as well.
Return to Interior
