by rushing » Mon 17.03.2008, 15:56
Hi i need to replace my rear plastic window. A car uphostery place have quoted me £211.00. do you think this is cheap or is it a rip off. ?
thanks
rushing
by Sy V » Mon 17.03.2008, 16:00
Sounds dear. Why do you need to replace your window?
- LEC Godfather
by rushing » Mon 17.03.2008, 16:17
misty and grey . i cant even see and reverse . too old now . plastic cracking .
rushing
by Sy V » Mon 17.03.2008, 16:19
If it's cracked then fair dos. But Renovo plastic window polish will clear the misting - I promise you.
Sy V on Mon 17.03.2008, 17:09, edited 1 time in total.
- LEC Godfather
by rip » Mon 17.03.2008, 16:54
MER car polish does an ok job too. You are more likely to have some of that already.
by clemo » Mon 17.03.2008, 18:50
save yourself time money( at that price) and future effort get a new hood or a new hood plus seals from trims..
if not shop around , thats very expensive,,,
clemo
- LEC Administrator
by markv » Mon 17.03.2008, 22:25
Sy V wrote:If it's cracked then fair dos. But Renovo plastic window polish will clear the misting - I promise you.
Sorry, but it doesn't work for bad cases - I've tried. Yet to try the MER.
by Sy V » Tue 18.03.2008, 06:41
I find this hard to believe, Mark. Is there some other outside influence that has tarnished your window?
I agree that it takes time. But working in small circles, inside and outside surfaces, it should do the trick.
After all, it's only a plastic polish - mild abrasive.
- LEC Godfather
by Galsia » Tue 18.03.2008, 08:30
Sy V wrote:I find this hard to believe, Mark. Is there some other outside influence that has tarnished your window?
It didn't work on my rear window but mine is too far gone for cleaning I think..
Thread about it here.
Galsia
by markv » Tue 18.03.2008, 12:22
The rear window was in a bad state when I bought my elan - the previous owner said she'd tried all sorts of things but nothing worked. So far I've done two applications of Renovo (small circles, inside and out) and there was an improvement, but not enough to give me anything approaching good visibility - I can now see vague shapes rather than just a mist!
I think I took some before and after pictures, so if I can dig them out I'll post them.
by Sy V » Tue 18.03.2008, 13:04
Blimey!
I thought mine was bad - yours must have been like pea soup!
- LEC Godfather
by Scott J » Mon 25.08.2008, 16:21
I use the Renova and stevo tried it to. If window is way past its best Renovo will not bring it back to new. it does improve visibility but I find myself polishing the window every 6 months. "running to stand still"
Scott J
- The prodigal son
by ektrolleyboy » Thu 04.09.2008, 11:09
Does anyone have any experience of Hindsight screen restorer? Is it really as good as it's made out to be? Before I go and blow 40 squid on a kit...
ektrolleyboy
by Jackonicko » Thu 04.09.2008, 15:15
It's got to be worth a try. The next step will cost you £200 minimum, or eight long and painful hours.
Jackonicko
by dermotbell » Thu 04.09.2008, 19:44
Tried it, not going to get rid of the dreaded misting, but it is better than renova.
Dermot Bell
dermotbell
