hood repair
hood repair
Postby The Ref » Sat 12.04.2008, 07:50
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
Location: The "pools" HUFC must win a game some day soon
Postby Sy V » Sat 12.04.2008, 07:54
Howzat!
Wicket... Wiki it!
LEC Godfather
Postby GeoffSmith » Sat 12.04.2008, 08:46
Postby RayD » Sun 13.04.2008, 22:46
Will anyone whose roof will close without having to move either of the cross stays forward with your left hand, check a measurement for me…
With the soft top closed, check the two centre cross stays are about 10⅝” apart, then see what they are when the roof is half open, in other words with the front end lifted.
I could do with knowing on Monday morning if it’s no trouble.
Thank you very much
Ray
RayD
Postby Rambo » Mon 14.04.2008, 08:46
RayD wrote:With the soft top closed, check the two centre cross stays are about 10⅝” apart...
26 cms in new money Ray
RayD wrote:then see what they are when the roof is half open, in other words with the front end lifted
22.5 cms
Postby RayD » Mon 14.04.2008, 13:21
Thank you for that Mark,
Ray
Hmmm.....1/894th of a furlong :?
RayD
Postby Galsia » Mon 14.04.2008, 14:13
What kind of webbing did you use and where did you get it from?
Galsia
Postby The Ref » Mon 14.04.2008, 17:15
Galsia wrote:What kind of webbing did you use and where did you get it from?
any saddler will keep it in stock. i used the same grade used on sports bags etc good and strong.
The Ref
Postby GeoffSmith » Mon 14.04.2008, 20:01
RayD wrote:Hmmm.....1/894th of a furlong :?
Fancy new measurements! What's wrong with 125/2794 of a perch? :wink:
Postby RayD » Mon 14.04.2008, 20:18
Is it accurate like mine Geoff or have you just plucked a figure out of thin air? :?
Ray
RayD
Postby GeoffSmith » Mon 14.04.2008, 20:24
Work it out for yourself! :smt019
I had to with yours. :lol:
Postby DeeAitch » Mon 14.04.2008, 21:00
Reminds me of Dogs Mead all those years ago :oops:
DeeAitch
Postby dapinky » Tue 15.04.2008, 01:17
So then, just to clarify, am i to assume that the distance referred to is just shy of half a cubit?
Postby The Ref » Tue 15.04.2008, 07:32
Sy V wrote:Howzat!
Wicket... Wiki it!
Sy
How do i get it on WikiLEC ?
Billy
The Ref
Postby RayD » Tue 15.04.2008, 09:43
Billy
Start Here
Ray
RayD
Postby GeoffSmith » Tue 15.04.2008, 13:01
dapinky wrote:So then, just to clarify, am i to assume that the distance referred to is just shy of half a cubit?
I'm disappointed Dave. Thought you'd have gone for just under a Span - "the width of a human hand, from the tip of the thumb to the tip of the pinky finger". :D
Postby The Ref » Tue 15.04.2008, 17:35
RayD wrote:
Billy
Start Here
Ray
thanks
http://lotuselancentral.com/forum/viewt ... 557#156557
The Ref
