by ppete100 » Wed 23.04.2008, 09:06
cooling fans not coming on at 3/4 mark, wanted to check earth on rad frame but where is it located??
pete
ppete100
by woody » Wed 23.04.2008, 12:44
Pete,
The earth to the fans is located at the top of the vertical section of the support frame, near the top of the radiator in the centre.Two 10mm bolts about 30mm apart.If you feel about you should touch the earth lead with ring joined to the earth cable.
Woody
woody
by Enright » Wed 23.04.2008, 12:48
I'm not sure but as it bolts to the front of the prongeron, maybe it's earthed through that. Or perhaps it has a positive and negative wire, running to the motors and back, in which case an earth wouldn't be necessary. To be honest I'm not sure.
But if you were to turn on the ignition and bridge the thermal switch as per Monty's instructions 6 posts down on this thread
here, then that may instantly verify where the problem IS while ruling out where it ISN'T.
Neil
- Modificator
by woody » Wed 23.04.2008, 12:53
Pete,
Check/change your thermostat,it is the usual culprit !
Woody
woody
by Ade » Wed 23.04.2008, 15:13
Woody is right where it is. Perhaps a little off the thread,but if anyone as duff fans. I changed both mine for 2 pacet fans. You can remove the original fans completely, the new fans fit straight onto the rad no brackets required very easy to fit, and all plastic, they are 9ins and supposedly more efficient. I also fitted an independent switch so I can put the fan on any time. I think for 2, I paid £100. But remember they are either blowers or suckers I had the blowers and fitted them to the front of the rad.
Ade.
Ade
by Candles » Wed 23.04.2008, 18:21
Woody,
The thermostat doesn't affect when the radiator fans come on. They have their own switch.
Candles.
Candles
by Enright » Wed 23.04.2008, 18:25
But if hot water isn't getting past a stuck thermostat to the cold side (where the sensors are), then the fans won't be activated.
Neil
- Modificator
by woody » Wed 23.04.2008, 18:59
I agree Neil, it's happened to me.Fortunately I switched off in time.
Woody
woody
by dapinky » Wed 23.04.2008, 19:05
woody wrote:.....Two 10mm bolts about 30mm apart.If you feel about you should touch the earth lead with ring joined to the earth cable.
My bolts are 8mm heads (i only took 'em out a couple of days ago), it's the bolts between the prongeron and rad frame that were 10mm.
[of course, mine could be the 'odd ones out' here]
- LEC Administrator
by GeoffSmith » Wed 23.04.2008, 19:29
Quick way of checking the fans is to unplug the rad switch (the one after the thermostat on the thermostat housing) and to short it: Circuit diagram is on the
Wiki.
- Kitty Fiddler
Return to Heating and Cooling
