Drivetrain problems
by router » Thu 12.06.2008, 11:20
Is the gearbox and engine oil drain plug the same type bolt?
Both are 23mm head
m20 bolt 1.5 thread
Can they be put in either or?
The gearbox has an O ring and the engine oil drain has a copper washer is that the only difference?
Neil
router
by M100 TWO » Thu 12.06.2008, 13:47
NO they are different
diff
M100 TWO
by Sy V » Thu 12.06.2008, 13:48
I'm not certain they're the same actually...
Hah, John beat me to it.
- LEC Godfather
by rip » Thu 12.06.2008, 19:24
I don't think either of them have 23mm heads.
The gearbox one is 25mm. Try finding a 25mm socket though
I think the sump is a lot smaller, but I can't remember what size.
by router » Thu 12.06.2008, 23:12
I was thinking of getting a magnetic drain plug for the gearbox drain plug and the engine just need to know the size and thread type...
router
by Sy V » Fri 13.06.2008, 07:45
OK I have a new magnetic sump plug and a spare gearbox in my garage. Give me half an hour and I'll have a definitive answer for you...
- LEC Godfather
by lotusgirlmarie » Fri 13.06.2008, 07:46
Mine have a 22mm (oil pan) and a 24mm (transmission)
lotusgirlmarie
- Goddess
by Sy V » Fri 13.06.2008, 08:09
Engine Sump Plug is:
M14x1.50 with a 14mm head (but as this is an aftermarket spare the head size could vary).
Gearbox Plug is:
M20
x1.50
with a 24mm head.
- LEC Godfather
by router » Fri 13.06.2008, 08:29
Thanks very much, very helpfull
Neil
router
