Kia Rear Light conversion
Postby Gee0 » Sun 03.08.2008, 15:15
Form that can a assume that this configuration should be fine as long as it is more than 250mm above the ground.
Gee0
Postby dapinky » Sun 03.08.2008, 17:00
Gee0 wrote:Form that can a assume that this configuration should be fine as long as it is more than 250mm above the ground.
Not quite.....
The picture of Ratman's car shows the foglight on the left hand side of the car - ('cos it's in Italy!), but in the UK it needs to be on the right.
(also, all the other dimensions need to be complied with :wink: )
Postby Gee0 » Sun 03.08.2008, 17:40
yip point taken make sure they are on the right side to match up with the existing electrics.
Angles should be fine. :wink:
Gee0
Postby Sy V » Mon 04.08.2008, 05:21
Sy V wrote:...I think I have an old UK number plate plinth if you need it, Gerry...
OK, I'd better try and find that plinth that I think I have...
LEC Godfather
Postby Gee0 » Mon 04.08.2008, 18:02
Thanks Sy that would be great.
Gee0
Postby Gee0 » Wed 06.08.2008, 19:04
RIGHT
I think I have sourced some little lights to fit behind the grill in the rear bumper.
I was toying with just a 4 inch strip of LED like this; http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=017
I have gone for these,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=019
I think these will look good fixed to a small sheet of plastic or SS behind the grill.
I have just looked at the wiring and OMG makes no sense to me at all.
I thought it was a case of unpluging the old main lights and pluging in the new ones :roll:
NOOO can't be that easy
Gee0
Postby Sy V » Mon 11.08.2008, 08:20
Gerry
What I have is a perspex cover and the black plastic surround - no plinth as such.
This would be a lot easier to explain if page 12.08 hadn't gone AWOL from the parts manual.
LEC Godfather
Postby dapinky » Mon 11.08.2008, 16:55
Sy,
Is this the one you wanted?
Postby Sy V » Tue 12.08.2008, 08:02
That's what I have (thanks Dave) minus 022 and 005.
LEC Godfather
Postby Gee0 » Tue 12.08.2008, 16:49
ok thanks Sy
I wont take you up on your offer as dont think it will give to look I an after.
Thanks anyway
Gee0
Gee0
Postby Sy V » Wed 13.08.2008, 08:57
I know English isn't your first language Gerry, but WTF does that mean?
:wink:
LEC Godfather
Postby Gee0 » Wed 13.08.2008, 13:40
Gee0 wrote:ok thanks Sy
Thanks anyway
Gee0
Sy wrote:I know English isn't your first language Gerry, but WTF does that mean?
OK LETS TRY THAT AGAIN :-D
Thanks Sy, but I will not be taking you up on your offer of the numberplate cover, as it will not give me the look I am looking for.
Thanks Anyway
Gee
PS. Is that better!!!! :-D
Gee0
Re: Kia Rear Light conversion
Postby Gee0 » Mon 01.09.2008, 17:29
OK
I have an Auto-electrician sorted to fit the lights.
Question is can he fit the fog light and reversing light without removing the bumper?
If he removes the 4 hex bolts/scews from the underneath, is there enough give in the bumper for him to install and fix the new lights in place.(behind the gril at the bottom of the bumper)
If not can anyone give me a step by step account for removing and refitting the bumper so that I can give him a copy.
Can anyone that has fitted these Kia rear lights before give me/him any advice, snags that may occur?
Thanks in advance
Gerry
Gee0
Postby Sy V » Tue 02.09.2008, 08:09
The only two that I can remember Gerry, are the need to fettle the holes in the back panel to accommodate the larger rear gubbins on the Kia units.
Your electrician will need to do some re-wiring as well because they're wired differently and have different connectors IIRC.
LEC Godfather
Postby Gee0 » Tue 02.09.2008, 17:16
Thanks Sy
Yip got those 2
Any ideas on the bumper stuation?
Gerry
Gee0
Postby Gee0 » Tue 02.09.2008, 18:30
Hi
I have just had a look at removing the rear bumper
4 hex underneath
4 Bolts in the boot
4 selftappers 2 each side on the edge of the bumper to hold the wheel arch liner in place
This bumper must have been off before ( maybe when the Pleco was fitted) Very Very easy little pressure and all came loose.(10 min Job)
It looks like the bumper will have to come off to fit the lights. I have hand tightened all the fixing in place so that the guy doing the work can see how it comes off.
BIG QUESTION
Is there anything he should know about to make refitting the bumper easier?
thanks
Gerry
Gee0
Postby Sy V » Wed 03.09.2008, 08:22
I know the square root of FA about the bumper - sorry.
LEC Godfather
Postby Gee0 » Wed 03.09.2008, 12:22
Hi
Looks like I have sourced a rear numberplate plinth although cracked on one side, I only need the middle.
Am I right in thinking that the eyebrows over the lights are not refitted after the Kia lights are inplace?
gerry
Gee0
Postby Sy V » Wed 03.09.2008, 13:03
I didn't refit mine.
LEC Godfather
Postby Gee0 » Fri 05.09.2008, 22:03
YIPPEE
Got my KIA lights fitted today, I think there the nuts, look great with the Slik Red. :banana:
Some pics
Now I just need to get on and extend the Numberplate Plinth. (It will stay the standard colour for now and maybe spray it Silk Red later)
Before and After
After
Before
lotus 003.JPG (211.24 KiB) Viewed 6876 times
Gee0
