by Monty » Thu 15.06.2006, 16:50
Did anyone come up with a Part Cross-Reference for these? I`ve done a quick search on the forum to no avail. Or does anyone no the manufactures number so i can do a search on the net?
Mr Paul.P
I know u`ve talked about this, did u say they were a Ford part? if u could find out mate i would appreciate it.
If not i`ll just order from SJ`s and i`ll post the numbers, just trying to save pennys.
- Chunder King!
by ab2cv » Thu 15.06.2006, 22:17
I ordered mine from Paul Mattys and got it fitted at Kenny Browns in Hillington. Kenny seemed to suggest at the time that it was a Vauxhall Cavalier part but I couldn't confirm this either way.
Alan
ab2cv
by Paul.P » Thu 15.06.2006, 22:32
Will sort through all my old paperwork at the weekend, but i believe they were the same as on an escort or similar ?, nothing special, i just cross referenced the numbers thats on the bearings.
by Gary » Fri 16.06.2006, 18:46
I thought from an Escort too.
by Monty » Fri 30.06.2006, 11:03
Here`s the numbers which are on the front bearings
ITALY A 273B 201
Think this is the main part number
SKF BAHB 311396B
Done a quick search but only getting sites from china. Found this thou
http://www.peakbearings.com/wheel-bearings.htm
Bearing No.
PEAK
DAC39720037
FAG
542186A
KOYO
DAC3972AW4
SKF
BAHB 311396B
309639
Dimensions(mm)
d D B C
39 72 37 37
Weight
0.56 kg
Seal
B
Remarks
Found this for cross reference
http://www.gglotus.org/ggpart/m100xref.htm
- Chunder King!
by WillB » Wed 05.07.2006, 11:25
Looks like I might need a front wheel bearing.
Any update on the numbers?
WillB
by Enright » Wed 05.07.2006, 12:54
I have an unopened box with one in at home which I got off eBay.
I'll try to remember to have a look at it for the part number on it when I get back later, or just read the number off the side of the bearing casing.
Neil
- Modificator
by Monty » Wed 05.07.2006, 13:47
Enright13 wrote:I have an unopened box with one in at home which I got off eBay.
Was that a Lotus part? as i`ve already listed the manufacture number above of the bearing. Need Paul.P to get intouch with his nephew to fing out which Ford it is off.
Dave (from the NE) said he might beable to sorce them but don`t think he`s seen this thread yet
- Chunder King!
by Enright » Wed 05.07.2006, 21:39
Monty wrote:Enright13 wrote:I have an unopened box with one in at home which I got off eBay.
Was that a Lotus part? as i've already listed the manufacture number above of the bearing. Need Paul.P to get intouch with his nephew to fing out which Ford it is off.
Dave (from the NE) said he might beable to sorce them but don't think he's seen this thread yet
Nope, it's made by a company called PowerDrive, and has the number 311396B on the box and on the bearing (in hindsight, same as you quoted above). It also came with circlips. I've just found the transaction on my PayPal account - I bought a pair which cost £17.98 inc P&P. Seller's ID was "flipperdog02".
Neil
- Modificator
by Monty » Thu 06.07.2006, 00:12
Enright13 wrote:Nope, it's made by a company called PowerDrive, and has the number 311396B on the box and on the bearing (in hindsight, same as you quoted above). It also came with circlips. I've just found the transaction on my PayPal account - I bought a pair which cost £17.98 inc P&P. Seller's ID was "flipperdog02".
Thats bloody cheap, it`s just cost me bout £25 each from SJ`s
how did u know that they were the right ones when ordering? do u know what other car make and model they fit? so we can get them form the dealer.
- Chunder King!
by Enright » Thu 06.07.2006, 00:48
Monty wrote:Enright13 wrote:Nope, it's made by a company called PowerDrive, and has the number 311396B on the box and on the bearing (in hindsight, same as you quoted above). It also came with circlips. I've just found the transaction on my PayPal account - I bought a pair which cost £17.98 inc P&P. Seller's ID was "flipperdog02".
Thats bloody cheap, it's just cost me bout £25 each from SJ's
They were advertised as being for the Elan in the Lotus Parts section. No idea what other make/models they fit - the part code already quoted should be sufficient.
Neil
- Modificator
by Monty » Wed 19.07.2006, 14:47
Found another site with a couple more Alternative numbers + says there for BMW, Opel, Ford but doesn`t give model or year.
http://www.nwideuk.com/bearings/automotive-wheel-hub.asp
Bearing No.
KOYO------BREDA----FAG---------SKF-----------IRB--------SNR------BCA
DAC--------C491---542186A----309639------IR-8085--GB12776---B-83
3972AW4-----------------------BAHB31-1396B
Dimension (mm)---------------------Car
d----D----B----
39--72---37---37--------------------BMW, Opel,Ford
- Chunder King!
by Paul.P » Wed 19.07.2006, 17:02
Have spoken to nephew, he was sure the rear bearing was off an escort, & as for the front bearing, they are available from Automotive Bearings Ltd, kit number PWK 0551, & are £19.71 + vat, about the same price as SJ's.
by Monty » Fri 21.09.2007, 17:04
dapinky wrote:There are lots of different Vauxhall numbers for various models, having measured the ones in the garage, they are the same as the measurements put up a while ago by Algirdas, and confirmed elsewhere.
The Vauxhall part number is 90486460
and they are easily available on
e-bay
If the Above number is correct then u can also get them here
www.vauxhall-car-parts.co.uk/acatalog/Calibra-Front-axle.html for £15 includes vat and it`s about £3.50 postage
- Chunder King!
by rip » Sat 22.09.2007, 08:34
Monty wrote:dapinky wrote:There are lots of different Vauxhall numbers for various models, having measured the ones in the garage, they are the same as the measurements put up a while ago by Algirdas, and confirmed elsewhere.
e-bay
www.vauxhall-car-parts.co.uk/acatalog/Calibra-Front-axle.html for £15 includes vat and it's about £3.50 postage
I cannot see why Lotus would NOT use Vauxhall parts, so I am going to take the plunge and get these.
by G UK » Tue 05.02.2008, 15:59
rip wrote:Monty wrote:dapinky wrote:There are lots of different Vauxhall numbers for various models, having measured the ones in the garage, they are the same as the measurements put up a while ago by Algirdas, and confirmed elsewhere.
e-bay
I take it that these are the correct ones then, can anyone confirm?
G UK
by The Ref » Thu 24.04.2008, 16:47
G UK wrote:rip wrote:Monty wrote:dapinky wrote:There are lots of different Vauxhall numbers for various models, having measured the ones in the garage, they are the same as the measurements put up a while ago by Algirdas, and confirmed elsewhere.
e-bay
Lads i need to do both of mine asap has any one fitted one yet ? if so what is the vauxhall part number ?
thanks
billy
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
- Location: The "pools" HUFC must win a game some day soon
by Enright » Thu 24.04.2008, 22:30
You are kidding aren't you?!? What's wrong with the part number in the post that you just quoted?
And yes, they fit fine.
Neil
- Modificator
by The Ref » Fri 25.04.2008, 09:06
Enright wrote:You are kidding aren't you?!? What's wrong with the part number in the post that you just quoted?
You are a star my mate thanks. i will order them to day.
Billy
The Ref
by DeeAitch » Wed 20.08.2008, 15:38
Fitted an Astra bearing last week
Not sure of other GM bearings but the Astra ones come with 2 circlips which you will need
although you could get away with using the old ones - they are muckle
DeeAitch
