by muley » Fri 01.08.2008, 23:09
OK,
This is probably a stupid question but I ask it anyway;
the exhaust manifold studs are torx ended - accordin to Dave's Myers write up they are T-40. So I need a FEMALE torx socket to get them out...
.. but the female torx sockets are referenced E6,8. 10 and so on.
So - which E number matches the T40?
Info needed so I can order a set to attack the turbo etc ..
by Monty » Fri 01.08.2008, 23:24
Jim,
I don`t know the answer to your question but IIRC i used a 5.5mm (or maybe 6.5mm
) socket to remove mine and for the tight space ones i used the spanner for bleeding my wilwood calipers which i think was 1/4"
- Chunder King!
by Doug » Sat 02.08.2008, 07:32
Jim,
Saab's use Torx screws, so needless to say I have a few sets of them now
I've only heard of the T- numbers though
I quickly eyeballed a T40 and it seems close to a 5mm hex; try some hex heads and see.
You're saying you can't buy a T40 in a set of tips?
-D
- LEC Founder
by GeoffSmith » Sat 02.08.2008, 10:26
E numbers are for external Torx such as you've got on the manifold studs and the numbers are somehow related to the distance between the crowns. Sorry Jim, but I don't know what number they are.
- Kitty Fiddler
by GeoffSmith » Sat 02.08.2008, 10:27
- Kitty Fiddler
by dapinky » Sat 02.08.2008, 10:30
e8 is the size you need for the exhaust manifold studs.
Don't ask me why it is similar in dimensions to the T40 - i don't know if there is any correlation between the two systems
(by the way - i'm not just going on memory - i've just been and tried a socket on a stud!)
- LEC Administrator
by Doug » Sat 02.08.2008, 16:06
GeoffSmith wrote:E numbers are for external Torx such as you've got on the manifold studs and the numbers are somehow related to the distance between the crowns.
a-ha, that makes sense . . .
- LEC Founder
by muley » Sat 02.08.2008, 20:57
Monty, Doug, Geoff, Dave,
Thanks a lot for the speedy and helpful responses
by nitroman » Sat 22.11.2008, 07:58
torx plus MANY other specialty bits, this kit is a helluva good deal.
http://www.griotsgarage.com/product/49140.do?code=EMRRV
nitroman
Return to Tools
