by Fumello » Fri 23.01.2009, 19:18
i had to replace my head gasket with a copper one, does anyone know the stock thickness of the gasket?
Thank you all
Francesco
'95 Lotus Elan S2
'04 Maserati Coupé Cambiocorsa
Fumello
by theelanman » Fri 23.01.2009, 20:24
are you trying to make your own gasket?....
if so I would not....only because the lotus ones are good quatity and pretty cheap for what they are
just my thoughts
cheers
gareth
by Specky » Fri 23.01.2009, 20:26
Are we talking N/A or SE
by Fumello » Sat 24.01.2009, 11:02
Sorry i have to place an orded to hussey for a new copper head gasket, the Elan is a '95 S2 so it is turbo.
Thank's again for your help
Francesco
'95 Lotus Elan S2
Fumello
by Ekapol » Sun 25.01.2009, 06:58
I don't have experience about the copper gasket but I would say please stay away from an after market one. They are cheap piece of junk and caused me another head gasket job after few weeks of just having it serviced.
OEM gasket from Lotus or Isuzu is always a safer way to go.
Ekapol
by Monty » Sun 25.01.2009, 12:30
I think Costas had a custom head gasket made so might be worth having a word
- Chunder King!
by Fumello » Mon 26.01.2009, 23:07
so really no one has an idea how thick the oem gasket is?
F
'95 Lotus Elan S2
Fumello
by Enright » Tue 27.01.2009, 14:03
I should be able to check later - I have a used and an unused one.
I'm wondering where it would be best to check it - around the pistons or from one of the sides in the "fibre-y" bit.
Just thinking that it might compress a bit.
Sod it, I'll do both, but only have a vernier so it's not going to be THAT accurate...
Neil
- Modificator
by dapinky » Tue 27.01.2009, 17:07
Enright wrote:Sod it, I'll do both, but only have a vernier so it's not going to be THAT accurate...
I have a 'used' one, but not a new one - I can measure it on the same places as you, but i have both digital verniers, and a micrometer, so with my measurements, you may be able to get an accurate 'guestimate' of your new one?????
- LEC Administrator
by lotuska » Tue 27.01.2009, 18:28
Check out the following
thread...somewhere down there I measured the thickness of both an original and a replacement (from kmckmc) head gasket. And I measure both the gasket and the metal reinforcements around the cylinders.
Hope that helps.
lotuska
by RayD » Tue 27.01.2009, 19:16
lotuska wrote:
Firstly I checked the thickness of each head gasket using my trusty micrometer...
Thickness of gasket material
- Lotus Original 1.22mm
- kmckmcs replacement 1.65mm
Thickness of "metal" bits around cylinders etc
- Lotus Original 1.35mm
- kmckmcs replacement 1.75mm
RayD
- Forum Member
by dapinky » Tue 27.01.2009, 20:01
Thanks for that - I shaln't bother then!
- LEC Administrator
