Misfire again
Re: Misfire again
Postby GeoffSmith » Sun 08.02.2009, 12:26
Martin, is it an S2? If so, it's most likely your O2 sensor otherwise I'd suspect a leaky injector.
Re: Misfire again
Postby Specky » Sun 08.02.2009, 12:50
GeoffSmith wrote:Martin, is it an S2? If so, it's most likely your O2 sensor otherwise I'd suspect a leaky injector.
It's an S2.... and it's Liz's... :wink:
Re: Misfire again
Postby GeoffSmith » Sun 08.02.2009, 12:56
Bet it's the O2 sensor then... ElanScan will confirm.
Re: Misfire again
Postby Martin R » Sun 08.02.2009, 18:11
That then begs the question could anyone close to me do one ? In exchange for beer tokens of course :D
2 Lotus and ones got to go :-(
Martin R
Re: Misfire again
Postby Martin R » Tue 10.02.2009, 20:48
Could someone help me out with this please. i will gladly pay for their time and effort. I really need to sort this as im getting made redundant next week. The Elise is virtually sold and either Liz or i need to use the Elan as a daily driver. there is absolutly no work about even for skilled men as i am finding out unfortunatly. I would gladly take it to someone but its undrivable at the moment :(
Martin R
Re: Misfire again
Postby niall » Tue 10.02.2009, 21:11
Hi Martin,
I am in Worcestershire and have a USB interface for Elanscan but no laptop loaded with Elanscan. If you have the latter and would like to borrow the interface, you are very welcome. That should enable you to diagnose the problem.
niall
Re: Misfire again
Postby theelanman » Tue 10.02.2009, 21:17
Martin R wrote:im getting made redundant next week. there is absolutly no work about even for skilled men as i am finding out unfortunatly.
Martin
sorry to hear about the job...guess its yet another sign of the times....
Ive been sat doing not for nearly six months and not found anything yet....
I do hope it all starts to pick up very soon.....if it doesnt Im off to Oz for a bit I think...better than the other option of kazahkstan :shock:
good luck with your job hunting
cheers
G
Re: Misfire again
Postby Martin R » Tue 10.02.2009, 21:36
Gareth, its the second time for me. Automotive manufacturing is a bloody nightmare now. In fact any manufacturing industry is in this country. I would fix Elans for a living but i would starve to death :-D
Martin R
Re: Misfire again
Postby Martin R » Tue 10.02.2009, 21:37
niall wrote:Hi Martin,
Thanks for the offer but ive not got the software either.
Martin R
Re: Misfire again
Postby niall » Tue 10.02.2009, 21:44
I believe you can download the software here. All you need is a PC or Laptop within cable's range of your car.
niall
Re: Misfire again
Postby ailwyn » Tue 10.02.2009, 22:03
Martin,
O2 sensors have been bought from the US, RockAuto IIRC, some have purchased individually or there was a cambelt group buy a (fairly long) while ago sorted by Hegg... if you can find that thread the part number is on there.
I would start working on removing the old one now though.. it's an absolute bitch to remove.
Ailwyn
ailwyn
Re: Misfire again
Postby Martin R » Tue 10.02.2009, 22:25
niall wrote:I believe you can download the software here. All you need is a PC or Laptop within cable's range of your car.
Super, ive found it. I will try and download it to the laptop tomorrow. I may well be in touch shortly :D
Martin R
Re: Misfire again
Postby Monty » Wed 11.02.2009, 00:50
Martin R wrote:Could someone help me out with this please. i will gladly pay for their time and effort. I really need to sort this as im getting made redundant next week. The Elise is virtually sold and either Liz or i need to use the Elan as a daily driver. there is absolutly no work about even for skilled men as i am finding out unfortunatly. I would gladly take it to someone but its undrivable at the moment :(
Martin, Sorry to hear that your being made redundant and fingers crossed and just hope things pick up soon.
I can`t really help on the Elan front but i`m sure the lads will get her help get her back running again.
Re: Misfire again
Postby Martin R » Wed 11.02.2009, 19:14
Right ho then. Ive found a laptop with a serial port i can use and put Elanscan on it. Niall ive have sent you a message in regards to the interface lead. I must say Elanscan looks mighty impressive a should give a few clues. Any tips before it try it ?
Martin R
Re: Misfire again
Postby Sy V » Fri 13.02.2009, 07:07
Martin
I have an interface or indeed, an Elanscan laptop and interface you can borrow.
I'm off today but I'm meeting someone at Upton Warren this morning. I'll be in my watering hole this evening though.
Is that any good? You can borrow Stripey if you want - I don't use her.
Apologies for not noticing this dilemma earlier and really sorry to hear about you employment situation.
Let's get this sorted...
Sy
LEC Godfather
Re: Misfire again
Postby Martin R » Fri 13.02.2009, 08:56
Simon, i will see you in the watering hole later. I only need the lead. I will try it over the weekend and see what i get. Thanks for the offer of the car but hopefully it will not come to that. I would hate to start getting up at the crack of dawn and start washing it ;-)
Martin R
Re: Misfire again
Postby stonefish » Fri 13.02.2009, 23:17
hi,
ive got working elan scan and a spare o2 sensor sitting here...only problem is im in essex..and my s2 is off the road awaiting rear brake discs...too far for you to travel i think????
jeff
stonefish
Re: Misfire again
Postby Martin R » Sat 14.02.2009, 10:04
stonefish wrote:hi,
jeff
Thanks for the offer but i should now be OK. Ive got the lead off Sy. I will give it all a try later after i have waved the Elise bye bye :(
Martin R
Re: Misfire again
Postby Martin R » Sat 14.02.2009, 14:32
Can someone have a peep at this please. Its still running rough. The O2 sensor is working it did however jump a couple of volts suddenly a few times. Thoughts please ? I just started the car from cold and let it run under its own steam.
Edit, im not sure if the file is zipped right. If its not can i email the file to someone to zip it or take a look. Let me know if this works please.
Edit, post edited to remove none working attachment :oops:
Martin R
Re: Misfire again
Postby GeoffSmith » Sat 14.02.2009, 15:19
Something appears to be wrong with the zip file - e-mail me the raw .ecu file and I'll have a look.
