by max and andy » Tue 24.03.2009, 19:22
Ratman would your plinth fit with stock S2 lights,without any gaps ?If you are thinking of making more i would be very interested. Top plinth .I would never of thought i would be buzzing over a plinth 6 months ago. Maxine.
max and andy
by Elanlover » Tue 24.03.2009, 19:46
max and andy wrote:Ratman would your plinth fit with stock S2 lights,without any gaps ?If you are thinking of making more i would be very interested. Top plinth .I would never of thought i would be buzzing over a plinth 6 months ago. Maxine.
I don't think that'll work as it would be too large for the stock clusters. The Kia lights are much smaller. The Kia kit comes with reverse lights (not installed on Ratman's car) that fit between the plinth and the ends of the Kia clusters. They are a few inches wide so the Kia clusters are actually a bit shorter than the stock cluster. Ratman's plinth is wider than the stock plinth to cover the gaps from the missing reverse lights. If you have a look at the pics of the red Elan on page 3 you'll see the gaps I'm referring to.
by Gee0 » Wed 25.03.2009, 09:41
Gee0
by ratman » Wed 25.03.2009, 11:55
the plinth has been made because of the different shape and the gap on the sides. the one in the phots is the pattern that (in my intentions) should be used for the mould. after it could easily possible to make a lighter CF or GF plinth.
I'm waiting for advices from LEC members, before!
Lotus Elan S2 n°538
ratman
by ratman » Fri 27.03.2009, 15:49
in any case, if you change the license plate lights with a smaller led couple, you could put the reverse light in the place of the Lotus badge. it should be easy to do!
Lotus Elan S2 n°538
ratman
by dapinky » Fri 27.03.2009, 16:38
ratman wrote:in any case, if you change the license plate lights with a smaller led couple, you could put the reverse light in the place of the Lotus badge. it should be easy to do!
I'm sure it could be done, but on a UK car, the fog lamp and reversing lamp will need to be on the oposite sides than if it is a Euro model
- LEC Administrator
by ratman » Fri 27.03.2009, 16:44
dapinky wrote:ratman wrote:in any case, if you change the license plate lights with a smaller led couple, you could put the reverse light in the place of the Lotus badge. it should be easy to do!
of course it could be made a hole both in the left or right side of the license plate.
the costrains are still the license plate under the plinth
Lotus Elan S2 n°538
ratman
by Blue_Bullet » Mon 28.09.2009, 01:54
Gee0 wrote:Just realised that I am missing 1 or 3 items to make this work
2 x reversing light covers
1 x Numberplate holder
The Pic is of one side of the reversing lights covers.
Any Ideas?
I have just niticed that it must be 3 items as the 2 sides of the reversing lights are in the pic and not the numberplate holder.
WHERE CAN I GET A SET OF THESE?
The answer is out there, It’s looking for you. And it will find you if you want it to!
Blue_Bullet
by Blue_Bullet » Tue 01.12.2009, 19:16
If that Plinth was made a bit wider on each side eg. where you have the Lotus Badge you could fit the Kia reverse+Fog Lights in Behind it!
( I know this has already been looked at! )
That would be perfect option for me, I also would still like to have a slightly tinted perspex cover over the middle bit where the number plate is situated to make it all look flush!
If anyone can make this for me or knows where I could get this made please send me a PM.
Blue_Bullet
