Petol flap cable & hood stowage lid cable
Postby Paul.P » Sat 02.05.2009, 19:32
Has anyone any experience of removing the handle & cable from the body on either of these ?
Re: Petol flap cable & hood stowage lid cable
Postby Specky » Sat 02.05.2009, 19:55
Yes... what do require..
Postby Paul.P » Sat 02.05.2009, 20:29
Just tell me how you get them off Specky please ?
Postby Specky » Sat 02.05.2009, 21:14
Ok it may take a while cos there's a few syles and types...
I'll start with the petrol cap early style
open the roof and rear deck
Hold them open with the battery bay cover
First remove the rear inner pannel, it sercured by Scrivets, you may break a few...
Situated towards the rear of the petrol flap assembly is the mounting point for the the wire
Open the access door and it will release one end of the cable
Open the passenger door you should see a nut,
Crack and undo this nut, you shouldn't have to hold the other side
remove the nut totally,pull the T-bar handle to it's fullest extent, this should give enough room to manipulate the whole wire through..
That's the first style out...
Off to find some old photos
Postby Specky » Sat 02.05.2009, 22:20
Early hood release
First remove the rear inner pannel, it's sercured by Scrivets, you may break a few...
The latches are situated on the left and right of the hood apperture
The easiest way is to remove the two bolts and rivets that hold each latch in place
Then crack the T-handle nut and manipulate inward, this is Quite hard thou...
The proper way is to;-
Start on the left hand latch...
Undo the lock nut
remove the R-clip
This should release the first cable
on the same latch
release the cable grip
Then release the cirlip and then remove lock nut
This releases one end of the second cable... :shock:
Now move to the other latch
Remove the circlip and pop the barrel out
Now move to the T- handle crack and undo the lock nut and manipulate the cable assy forward
And that's the early style...
Must go and do some chores, I'll be back
Postby Specky » Sat 02.05.2009, 23:34
Later releases
The latches are situated in the middle
The cables are retained by a nut on the back of the T-bar handle
The petrol cap is released as the earlier model, undo the nut and slide the whole assy out
The hood locks are the same principle
I can't find these photos... sorry
Hope all that helped...
Postby Paul.P » Sun 03.05.2009, 09:19
Specky, thats been of great help, thanks for the effort !
Postby Gary » Sun 03.05.2009, 11:00
Wow ! You can't ask for a more comprehensive answer than that !
Well done Specky - time to get your hands dirty Mr P
Postby Specky » Sun 03.05.2009, 12:37
But what's Mr P doing :poke:
Paul is in Rutland, which is near Essex, Essex has a connection with Lotus, Now if Paul had any blue bits of an M100... :-D
why let the truth get in the way of a good rumour
Postby Paul.P » Sun 03.05.2009, 13:02
It has been given some thought Dave ?
Can't you tell Gary's got nowt to do :!:
Postby Gary » Sun 03.05.2009, 16:24
He aint' got many blue bits left...
