by Sy V » Mon 02.03.2009, 10:19
Ooooh!
All these underneath tweaks may necessitate a larger spoiler (ironing board boy!)
seriously Phil, it's great to see this project getting the attention it deserves.
- LEC Godfather
by Monty » Mon 02.03.2009, 11:04
surferphil wrote:Monty wrote:Sounds like it`s slowly coming together, be good to see the final product
Are you still using the stock front bumper? Just wonder are you going to make a front splitter?
What about fitting undertrays for smoother air flow underneath like the Elise has
Yes, front splitter, full under tray, rear diffuser and the exhaust moved into the boot, out of the way as; not to spoil the airflow.
Original front bumper, slightly modified.
Nice
Any date set for it`s 1st outing?
Any chance off reproducing the front splitter
- Chunder King!
by surfboardfiller » Fri 06.03.2009, 22:53
Monty wrote:surferphil wrote:Monty wrote:Sounds like it`s slowly coming together, be good to see the final product
Nice
I think the front splitter would be the only part I am making which would fit a standard car, without cutting bits off.
surfboardfiller
by Monty » Sat 07.03.2009, 16:44
surferphil wrote:I think the front splitter would be the only part I am making which would fit a standard car, without cutting bits off.
Kool
How much?
- Chunder King!
by surfboardfiller » Tue 07.04.2009, 22:06
I stripped the dash last year and have lost the horn, lights switch and ignition switch wiring.
It's a Rats nest (not literally) so I am a little bemused. Of course wiring is not my thing so It's difficlt even when I know what I should be doing.
However I have a suspect; 3 wires in a sleve going from the ECU area. It's long enough to reach the speed o. Do you think it might be the ignition. The wires are purple black and purple with white stripe?
surfboardfiller
by GeoffSmith » Tue 07.04.2009, 22:15
What sort of connector(s) have they got on the end Phil?
Purple and white is used in the
interior lights.
- Kitty Fiddler
by surfboardfiller » Tue 07.04.2009, 23:15
That's what it is then; Rear view mirror wiring.
It's a shame I still have to find the ignition, horn and light switch....
Thanks,
surfboardfiller
by surfboardfiller » Fri 10.04.2009, 17:57
I found the ignition Switch!
Do you know for sure what these terminals are for, so I can wire up my new race switches.
- Attachments
- Ignition-Switch.jpg (36.55 KiB) Viewed 9389 times
surfboardfiller
by paulwatkins » Fri 10.04.2009, 18:29
Heres the ignition switch from the electrical manual.
B=Black
R=Red
BR=Black with red stripe
That takes care of the three larger wires....not sure about the smaller one though. Cant find mention of that, and I cant think what it could be for at the moment.
- Attachments
- Ignition switch.jpg (31.67 KiB) Viewed 9384 times
paulwatkins
by GeoffSmith » Fri 10.04.2009, 19:58
DIN 72552 15= ignition supply, 50=starter so presumably the number under the red lead is 30. Doesn't say what WP is though - Is it a three position (plus off) switch? Is it the radio supply? Did the radio work without the ignition on?
- Kitty Fiddler
by Sy V » Sat 11.04.2009, 06:13
It hasn't had a radio in it for donkey's years, Geoff.
- LEC Godfather
by GeoffSmith » Sat 11.04.2009, 09:31
I assume then that it was before your time or too long ago to remember the details. The only other check is to try the switch itself to see how many positions it has - hopefully Phil hasn't wrecked it.
- Kitty Fiddler
by Sy V » Sat 11.04.2009, 11:22
I've missed something here... why would it [the ignition switch] be any different to any other Elan?
- LEC Godfather
by GeoffSmith » Sat 11.04.2009, 12:09
'Cause it appears to have an extra terminal (WP).
- Kitty Fiddler
by surfboardfiller » Sun 12.04.2009, 01:12
It is indeed number 30.
According to the handbook:
The ignition (standard GM part)
Insert Key: Position B
1st turn to release the steering lock: Positon I
2nd turn to switch on Axillary power: Position II
3rd turn to crank the motor: Position III
Federal Market Cars have radio power on position I (this could be it)
Domestic market Cars have constant radio power for factory fitted radios
The wires from the switch go to a 4 pin connector plug. I'll photograph it (with my new digital camera) but as far as my notes go:
there are 3 wires (in my note book) on the female socket of the connector:
Brown (thick wire)
White (thick wire)
White with red stripe
I'll get some sensible pics of this connector asap
surfboardfiller
by surfboardfiller » Sun 12.04.2009, 22:16
As suspected, the thin red wire goes no where.
I should have enough info now to wire up the start switches.
Thanks,
- Attachments
- Ignition-Switch2.jpg (52.76 KiB) Viewed 9211 times
surfboardfiller
surfboardfiller
surfboardfiller
by Dave Eds » Thu 16.07.2009, 13:05
Users browsing this forum: No registered users and 17 guests
