GeoffSmith wrote:
The actual figures I achieved at my last MoT were
0.423% and 95ppm
For comparison mine were
0.17% and 75ppm
Ray
0.423% and 95ppm
0.423% and 95ppm
0.17% and 75ppm
Ray
owentec wrote:Is it likely that our car should have a cat on it and its been removed by a previous owner? The car was manufactured in Jan 92 and registered Sept 92.
rip wrote:owentec wrote:Is it likely that our car should have a cat on it and its been removed by a previous owner? The car was manufactured in Jan 92 and registered Sept 92.
Doubtful.
I have not heard of any UK SEs which had a cat from new.
A CAT'ed car would have an O2 sensor (&1499 ECU to understand it) otherwise the emissions would clog up the cat.
Removing the O2 sensor, swapping the ECU & fitting a CO pot is a lot of work for no gain so I doubt anyone would have done this.
Your O2 sensor would stick out of your turbo heat shield. If you have a blanking bolt there, you've not got one.
max and andy wrote:So am i right in saying that reading the posts and figures given. (A thread how to read the emission figures guide would be good) Unless you have a friendly MOT man. Or your S2 is tested as an SE as an oversight. Your S2 will not pass the computerised max figures set by the DVLA if logged in as an S2.
Without a cat fitted. Is that correct? Andy
GeoffSmith wrote:A recap and summary of the details of my experiences:
Both testing stations that have passed my car used a single CO maximum limit of 3.5% and HC maximum limit of 1200ppm. I did question this at my first MoT, but was told that the figures were taken directly from the DoT database. The actual figures I achieved at my last MoT were 0.423% and 95ppm respectively. These are taken from the computerised Sun DGA 2500 printout. I am unsure whether the CO figure is taken at idle or fast idle, however it is obviously below the 0.5% @ idle but above the 0.3% @ fast idle general guide figures quoted in Haynes.
Do any S2 owners have different limit figures (i.e. idle and fast idle limits for CO emissions) and if so, what are those limits?
max and andy wrote:Are you getting rid of the Gunk-ed up pre cat Paul? Looking at our old one its a must just to let the engine breath again properly. A&M
