+53 Work Wheels (now custom JLine wheels @ +60)
Re: +53 offset Work Wheels
Postby Monty » Mon 13.10.2008, 12:17
That looks Kool 8) and goes with the white M100 :smt023
Re: +53 Work Wheels (now custom JLine wheels @ +60)
Postby XiPHiAS » Sun 09.11.2008, 14:49
can u please post more pictures ?
I like to see how deep the wheels are into the weel arches, the front and back view ...
1994 Lotus Elan S2 #131 // Lotus Elan M100 S2 Registry
http://www.lotusforum.be :: Benelux Lotus Community
Ypres Lotus Day - International Lotus gathering & tour
XiPHiAS
Postby Elanlover » Sun 09.11.2008, 15:05
The wheels sit exactly the same depth as the OEM wheels - that's the whole reason for going with the +60 offset. I'll take more pics when I get a through raking all the leaves and the other fall garden work I've been neglecting :roll:
Postby Don.Hasi » Mon 25.05.2009, 23:49
Elanlover: Don´t you have weighed the wheels ??? How much are the 16" FED-stock and the good looking new ones?
And which tires do you use? Depending on the exact type their are great differences in same heights... so there could be a chance, that the harsher feeling could be reduced for those instead of you, who like the smoother way.
Don.Hasi
Postby Elanlover » Tue 26.05.2009, 02:56
Don.Hasi wrote:Elanlover: Don´t you have weighed the wheels ??? How much are the 16" FED-stock and the good looking new ones?
I weighed both the stock and the new wheels and they were almost identical. Not surprising since there's a fair bit more aluminum in a 17" wheel. Now that I've driven the car more I have to say I really don't notice the difference all that much. I have adjustable ProTech shocks on the car and have the suspension turned up pretty tight. So it was "harsh" even with the stock wheels on. Also, with new rubber, the tires haven't broken in yet (only 800km on them) compared to the older, more pliant tires on the stock wheels. I suspect that in another 1,000 km the tires will start to give more. I've had the original Goodyear Eagles on the old wheels and new Eagle F1's on the new wheels.
I'm going to calculate out the difference in the speedo and odometer if I used 45 profile tires on these wheels instead of the 40's. Just curious as 45's would fill in the wheel arches nicely.
Postby XiPHiAS » Thu 28.05.2009, 18:23
can u post more pictures please?
XiPHiAS
Postby bratboy_y2k » Fri 29.05.2009, 01:04
i just got off the phone with a wheel company. 17" wheels with a +53 offset look available. they weight in at 16.5 pounds each which will greatly aid in a smoother ride with the extra sidewall gone on the tire. so they are light, almost the right offset and i think they will come in at 750-800usd for a set of 4. he is looking into 16" wheels in the same offset but he doesnt know if they are available. so is anybody interested?
bratboy_y2k
Postby Elanlover » Fri 29.05.2009, 02:58
XiPHiAS wrote:can u post more pictures please?
Here you go. One thing I may have forgotten to mention is that with the new wheels the steering seems "lighter" - in a good way. Easier to turn in and a bit more responsive.
Postby bratboy_y2k » Fri 29.05.2009, 04:24
lighter steering would be great since its on the heavier side. im hoping we can get these light wheels i think i have found
bratboy_y2k
Postby XiPHiAS » Fri 29.05.2009, 10:49
thx!
but ... not just the wheel ... I like to see how the wheels match the car ...
(in my search of good and nice wheels for my elan)
XiPHiAS
Postby XiPHiAS » Fri 29.05.2009, 10:50
bratboy_y2k wrote:i just got off the phone with a wheel company. 17" wheels with a +53 offset look available. they weight in at 16.5 pounds each which will greatly aid in a smoother ride with the extra sidewall gone on the tire. so they are light, almost the right offset and i think they will come in at 750-800usd for a set of 4. he is looking into 16" wheels in the same offset but he doesnt know if they are available. so is anybody interested?
yes, more info please (but use pm... I don't want to hijack Elanlovers tread :))
XiPHiAS
Postby Elanlover » Fri 29.05.2009, 13:23
XiPHiAS wrote: but ... not just the wheel ... I like to see how the wheels match the car ...
I thought your post above asked for pictures of the wheels and how far they stick out of the wheel wells???? Have you looked through ALL the pictures in this post???? Not sure there are any other perspectives I can photograph. :smt017
Return to Wheels and Tyres
