Yella Fella
Re: Yella Fella
Postby lotos » Mon 06.04.2009, 01:12
He had them powdercoated himself a few months ago. I had read in previous threads that Marie's been offering to polish her pipes (for a fee)
But I'm guessing they're both made from aluminium. ;-)
lotos
Re: Yella Fella
Postby lotusgirlmarie » Mon 06.04.2009, 05:06
Top Ends are mild steel last I checked.
lotusgirlmarie
Goddess
Re: Yella Fella
Postby Doug » Mon 06.04.2009, 18:05
Matt, car looks great!
I vote black spark wire cover.
In case you forgot, I'll remind you to fill that extra hole in the intake plenum with the thingy to help hold the throttle cable in place . . .
Re: Yella Fella
Postby nitroman » Sat 11.04.2009, 09:53
GeoffSmith wrote:
nitroman wrote:The lower-temp (165F) thermostat works great
:shock: Surely you mean 180°F Matt.
No, 165F.
nitroman
Re: Yella Fella
Postby nitroman » Mon 27.04.2009, 01:00
A few minor things improved. I didn't get the picture angle right on the full-view to show both the polished fuel-rail & plastic-bracket bolts, which are just under the fuel-rail bolts as you can see.
nitroman
Re: Yella Fella
Postby nitroman » Sat 30.05.2009, 01:38
Converted car back to R-12 refridgerant today. Holy mother Fkng sht! I cannot relay with mere words how much, no, how COMPLETELY it transforms the A/C system. Anyone who converts to R134a is a dumb sht. :shock:
nitroman
Re: Yella Fella
Postby nitroman » Mon 01.06.2009, 03:27
Finally, error code 41 (no engine speed source). Plainly, you can see why.
IMG_1260 (Small).JPG (66.17 KiB) Viewed 14304 times
nitroman
Re: Yella Fella
Postby Doug » Mon 01.06.2009, 05:30
Matt, is that a MBC there upright next to the engine hanger?
Re: Yella Fella
Postby max and andy » Mon 01.06.2009, 06:03
I think the Black plug cover looked better to. What make of leads are they? A&M
max and andy
Re: Yella Fella
Postby nitroman » Mon 01.06.2009, 18:00
Doug wrote:Matt, is that a MBC there upright next to the engine hanger?
Huh? What? I have a classic brass-era pressurized accoutrement. That's all I see.
nitroman
Re: Yella Fella
Postby nitroman » Sat 12.09.2009, 03:22
I put in a new Optima red-top battery last week. The car probably had no battery hooked-up for an hour. I think that extended no-battery time is responsible for the fantastic way the car has run ever since. A few months ago, after I reset the timing I finally disconnected the battery for a half-minute, but that is not long enough for the ECU to reset itself. I can't tell you how long the battery must be disconnected, except to say it's longer than 30-seconds and shorter than an hour.
For the entire time I've owned this car, which has been well over a year, I have thought that it simply did not run as good as the other two Elans I've owned. It now runs exactly like the other two cars did, which is a very satisfying thing.
One other battery-related thing: I took out a 40lb battery and put in a 31lb one. I don't know how light you can go, or what the longevity of lightweight batteries are, but there are 15lb units available for Miatas. You don't appreciatte the difference this makes until you've huffed a 40lb battery across your yard!
nitroman
Re: Yella Fella
Postby nitroman » Sun 20.09.2009, 07:32
I bought a new exhaust-tip online today. I got a purely round one, inspired by the rather large one on Sh4rk. I wanted a 4" one but the one I liked best only came in 5". It has to come ground from North Dakota, so it'll be a couple of weeks before I get it on the car.
At 12" long, I'll have it cut to length & welded on.
http://www.realtruck.com/product/87356/ ... _tips.html
nitroman
Re: Yella Fella
Postby lotos » Sun 20.09.2009, 17:01
Yep, that's going to look great on your lifted pickup. It's for a lifted pickup, right? :twisted:
lotos
Re: Yella Fella
Postby nitroman » Sun 20.09.2009, 21:25
lotos wrote:Yep, that's going to look great on your lifted pickup. It's for a lifted pickup, right? :twisted:
Yes. I try to be a classy guy but fail. I also need to work on treating others with more decorum.
This is the only portion I'm going to utilize. The muffler-body is 5.25" x 8, so the tip's 5" OD will weld fine onto the distal end of the muffler. I'll point the MBRP logo inferiorly so I can be free to keep everything clean with metal polish.
nitroman
Re: Yella Fella
Postby GeoffSmith » Sun 20.09.2009, 21:27
nitroman wrote:I also need to work on treating others with more decorum.
He's not the only one, is he Randy? :poke: :-D
Re: Yella Fella
Postby lotos » Sun 20.09.2009, 22:09
Sheesh, just teasing - the site says it's for a pickup truck. :oops: :oops:
lotos
