by Gordon » Sun 19.07.2009, 09:09
Regarding the RH Drivers A-Post seal carrier -
Can anyone tell me the difference between A100U488F and B100U328F ?
The manual list the former, the windscreen people fitted the latter (it's stamped on it!) -former has been lost;
B100U328F seems to give me a terrible (impossible) fit on the A-Post seal, but I'm loathed to buy a A100U488F if it's the same part?!!
Gordon
1990 M100, Calypso Red
2005 Vectra C....
Gordon
by Specky » Sun 19.07.2009, 10:03
I'll have a look at the carriers which I've removed in the past and let you know the result during the day, I'll take some pics.
by Gordon » Sun 19.07.2009, 10:09
Specky wrote:I'll have a look at the carriers which I've removed in the past and let you know the result during the day, I'll take some pics.
Great, thanks!!
2005 Vectra C....
Gordon
by Specky » Sun 19.07.2009, 10:45
Here's a few pics:-
If you need high res just PM me your email addy
I can't see any Pt No's, saying that there's still quite a bit of sealant on them, where were your markings?
by Gordon » Sun 19.07.2009, 11:30
This is the one they've fitted - B100U0328F
Facebook album of seal carrierIf you can find part numbers, I'd be intersted in closeups of an A100U488F - looks to me like you may have one of each type there - mine has the stepped cut at the top end..
The carrier that've fitted on the LHS is an A100U487F, which is giving a perfect fit - needless to say, I'd rather not disturb it any more than to see the part number...
Gordon
2005 Vectra C....
Gordon
by Specky » Sun 19.07.2009, 12:07
Just replying
by Specky » Sun 19.07.2009, 12:18
Both sets are identical... the other set still has sealant and bits of seal on them, this made them look like the other varient...
Here's some pics...
Note to self....feed the Puppy at twelve...or don't use her paddling pool to take photographs on..
by Specky » Sun 19.07.2009, 12:49
Amend that last post, they are not identical, you were correct they are different...Good eyes...
I'm still trying to clean the other ones up, there soaking at the moment
There is three diferences that are instantly visible...
the mounting face is different...one has a channel
the channel is deeper on one side...Where the A-post seal sits
the new one is longer.... the pointy bit is the longer bit...
I'll post pics when I can clean it up a bit more...
by Gordon » Sun 19.07.2009, 12:57
Just for reference;
Peeling back my passanger side seal, it looks like that carrier is Also 5 screws (although they've left the bottom one out...) , but its defo part number A100U487 (with no F)
Added a pic in the Facebook album.
Gordon.
2005 Vectra C....
Gordon
by Specky » Sun 19.07.2009, 13:39
Here's some comparrision shots
I can't tell if the overall profile is different because I bent the latter version getting off...
One point of note is the drill holes are different... and some have been made by who ever fitted the carriers...
by Specky » Sun 19.07.2009, 13:41
Hope all that helps...
Give us a PM if you require any more pics...
by Gordon » Sun 19.07.2009, 14:05
Thanks for all the pics Dave,
Did you find any part numbers anywhere?
Specky wrote:Hope all that helps...
2005 Vectra C....
Gordon
by Gordon » Sun 19.07.2009, 14:29
One thing that does appear to be aparent is that the screw holes/slots on my new carrier don't seem to be in the same place as yours;
Can you possibly measure the distance between the holes? - starting for reference at the flat top end?
Mine are at: 10mm - 145mm - 280mm - 415mm - 550mm
Top - starting at 10mm
Down to bottom at 550mm
Gordon wrote:Thanks for all the pics Dave,
2005 Vectra C....
Gordon
by Gordon » Sun 19.07.2009, 14:42
Which of course also brings the next question!
Where should the carrier finish/locate?
This is my passenger side (which looks OK)
It appears to finish (Green arrow) about in line with the estimated edge of the glass (yellow arrow)
Any comparisons?
When my new drivers side carrier was installed, it did appear to be sitting around 5mm lower than the passenger side one..
Gordon
2005 Vectra C....
Gordon
by Specky » Sun 19.07.2009, 16:27
read it all...
Will do...
and I'll go to the other set I have and measure...Fitted to the white one
First of all tea...
by Specky » Sun 19.07.2009, 16:54
First answer....
The slots are the same distance, but someone has drilled their own holes... 10mm lower on the top 4 and 10mm up on the bottom...
Second answer.... stand by...It's raining cats and dogs..
by Specky » Sun 19.07.2009, 16:56
In fact I've just had a brain wave, I'll dig out the windscreen pillars and see where they fitted...
by Gordon » Sun 19.07.2009, 17:07
Dave,
Are you saying then that this distance is 10mm?
Yours:
Mine:
Gordon
by Specky » Sun 19.07.2009, 17:23
The new varient of carrier mirrors the profile of the window pillar...that top spikey section...
But saying that...that's using the self made holes, not the slots...If I were to use the slots it would sit lower...
I guess it's one of the S2 improvements,
So your new seal carrier is sitting 10mm to low
The other car has what appears to have the old carriers, they sit 5-10mm lower than the top of the windscreen
I'm guessing the new carrier isan attempt by Lotus to stop the top of the seal getting pushed back in the top corner when driving at speed...
by Specky » Sun 19.07.2009, 17:45
More pics...
