MattDon wrote:ok so cant do much major as i need to move the brg and i dont have enough wheels to go around, so i was looking at loki as ive got issues with my glass on both sides, long story short someone had moved the drivers side window in and it sits nicely but something was catching on the glass and marking it, it looked like a screw was causing the problem as ive had my door card off ever since and all the screw where put back it for safe keeping, so assuming it was a clearance issue i decided to remove the screw that looked responcible, its the bottom screw of the two that hold the door handle frame and the metal mouting brackets on the door skin, unfortunatley its snapped off and now the window only goes down 1cm before theres a realy nasty noise, im confused how undoing this screw could cause such a catastrophic problem, i guess my main question is just how screwed am im? ie can the broken screw be removed?
