1st i used the cleaner to strip the surface back to be able to paint, make sure that you don't spill the cleaner and do it in awell ventilated area.
next you need to mask the area making sure you get right into the corners and leave no risk of overspray.
3rdly paint ! make sure you apply in light coats with 3-5 mins between them and a max of 30mins. leave to dry for an hour or so and then carefully remove the masking tape
then lastly give the seats a day or two then give them a polish and stand back and admire your handywork
