Could anyone recommend a strong contact adhesive
Postby sponcom » Thu 22.10.2009, 11:48
I recently bought an elan and I'm in the process of restoring it. The previous owner has fitted a new roof but hasn't been fixed at the rear where the hood bar meets the bodywork. The roof has a seam that fold under the bar and is obviously glued there. Could anybody recommend a strong adhesive, maybe a contact adhesive for this area as it looks as though it will come under quite a bit of tension when the hood is up.
Paul
sponcom
Re: Could anyone recommend a strong contact adhesive
Postby GeoffSmith » Thu 22.10.2009, 12:36
Paul, this link may help.
Postby sponcom » Thu 22.10.2009, 14:01
That does indeed help!
Thanks very much!
sponcom
Postby dapinky » Thu 22.10.2009, 14:03
Paul,
Any good contact adhesive will do the job, but i use bostik 2402 which is a 2-part glue designed for rubbery type materials.
I firsty used it for inflatable boat and drysuit repairs (never had a leak yet!) and then have used it on elan hoods with success.
Postby GeoffSmith » Thu 22.10.2009, 19:08
Does anyone know where I can find a small quantity for roof reinforcing patches? :roll:
Postby dapinky » Thu 22.10.2009, 19:18
GeoffSmith wrote:Does anyone know where I can find a small quantity for roof reinforcing patches? :roll:
How much of a rush are you in :roll: :roll:
Postby surfboardfiller » Wed 28.10.2009, 22:45
I have a section of roof fabric if you need some Geoff. Just bond it on.
surfboardfiller
