Replacement Shift Cables
Drivetrain problems
Postby mti88m3 » Wed 04.08.2010, 14:17
Where can I find AB Shift Cables? They seem to be the best solution. I sent the fellow on here a message, but haven't heard anything back. Is there a source for these in the US?
mti88m3
Re: Replacement Shift Cables
Postby ashm » Wed 04.08.2010, 14:29
I think for the US you should go direct to AB Motorsport:
www.abmotosport.com/
Adam
ashm
Postby tigerdog » Wed 04.08.2010, 15:07
And welcome! Not too many Americans on the board. Please introduce yourself and your Elan sometime soon. I'm not sure how many other Elans you'll find in and around the Midwest but you may be surprised. AB cables are definitely worth fitting. Take your time routing them to insure they don't bind. While you're in there, you'll be very happy if you fit a short-shift (either AB or Dave's). I have the AB cable/Dave's shortshift combo and it's a night-and-day difference compared to the stock setup.
Postby mti88m3 » Wed 04.08.2010, 15:15
Perfect, thanks guys! I'll give them a call and see what we come up with.
Any idea what the cables and AB short shift cost? I'd be interested in doing it, but I don't really want to spend more than $1,000 on it right now.
The owner of a local Kia dealer has had his beautiful red Elan in his showroom for as long as I remember, I was really surprised when I spotted it. It's the only other one I've seen in person.
mti88m3
Postby Denny » Wed 04.08.2010, 15:49
PM sent with Alan Betts direct email. Good Luck.
Denny
Postby mti88m3 » Wed 04.08.2010, 16:48
Denny wrote:PM sent with Alan Betts direct email. Good Luck.
Thanks Denny, I'll check with him first.
mti88m3
Postby steve matthews » Wed 04.08.2010, 23:33
A.B. cables and the short shift :-D
Miles of smiles
Steve -w- new lady and the above installed.
steve matthews
Postby mti88m3 » Sat 07.08.2010, 01:05
Emailed Alan, and got the ball rolling, thanks for the help guys!
mti88m3
Postby mti88m3 » Tue 24.08.2010, 16:50
Got the replacement cables and short shift from Alan, they're beautiful! He shipped them on a Friday and I received them the following Wednesday.
Shifting fore and aft is fantastic now, side to side is a bit stiff, but it's loosened a little so far. It is stiff enough that it doesn't want to self center. Anyone know how long it takes to soften up a bit? Or do I need to file that bushing?
mti88m3
Postby steve matthews » Tue 24.08.2010, 22:25
I gave it about 100 shifts then removed it and filed it.
Couldn't stand it. :twisted:
Steve -w- new lady :m100:
Did you cut down the gear shift?
This makes it even better.
steve matthews
Postby Specky » Tue 24.08.2010, 22:30
Crackin photo's there, Good skills :-D
Postby mti88m3 » Tue 24.08.2010, 22:35
steve matthews wrote:I gave it about 100 shifts then removed it and filed it.
Yeah, I've been driving it a few days now, I'll have to pull it out and do that.
You cut the lever down? I haven't seen anything about that, how much did you take off?
Specky wrote:Crackin photo's there, Good skills :-D
Thanks! I always like to have plenty of project pics.
mti88m3
Postby Enright » Wed 25.08.2010, 00:03
Replacing the rubber bushes that mount the gear lever bracket to the chassis with delrin ones make it even better. 8)
Postby maz_r » Wed 25.08.2010, 00:08
Good timing; my cables are due from Alan anytime soon.
Great pic's which will help a lot with the fitting.
Apologies for the slight highjack, but which bush is it that I've seen mentioned several times that needs some filing? A picture would be very useful...... :wink:
maz_r
Binary Bodger
Postby mti88m3 » Wed 25.08.2010, 00:16
maz_r wrote:Good timing; my cables are due from Alan anytime soon.
See the last pic? The cable end with the black rubber bushing goes on just fine, the one not quite in the pic is the one that needs a little filing.
mti88m3
Postby steve matthews » Wed 25.08.2010, 01:14
You can cut a good 1/2 to 3/4".
Much easier with unit out of car.
Shift knob can still be original or aftermarket design.
Yes forgot the rubber bushings can be replaced making the unit one solid. :wink:
I believe Alan at AB also has these.
Steve
steve matthews
Postby rip » Wed 25.08.2010, 08:25
maz_r wrote:which bush is it that I've seen mentioned several times that needs some filing?
The one which is difficult to fit in the first place. :-D
Don't file it too aggressively or you'll introduce slop, or make it abrasive so it wears the pin.
File it gently, tidy up with some fine wet & dry paper, then apply some grease.
Postby steve matthews » Wed 25.08.2010, 13:58
Well said :-D
steve matthews
Postby racerstev » Tue 21.09.2010, 20:20
Very nice write up!! Can someone tell me the differance between the S1-S2-Isuzu and AB cables? I'm a little confused!
Steve Lockett
racerstev
Postby Peter D » Tue 23.11.2010, 20:59
Hi all,
On the Belgian Lotus Forum, I posted the question if there is interest in organizing a group buy of the AB Cables.
H2J came with the hint to post the question here as well.
So should we get some interest, I could bargain for a good price.
I can have all cablesets shipped to me, and sent those for UK to one address ?
Let me know if you're interested.
I'll keep the poll running untill december 14th. and then ask for a price quote.
Regards,
Peter.
Peter D
