front clam
front clam
Postby esext03 » Mon 27.09.2010, 15:11
I wish to check the power steering pump on my elan .The "book" advises that the front clam has to be removed first ,My question is does the clam have to come off before you can remove the pump?
Thanks et
The Honda was SO MUCH EASIER
esext03
Re: front clam
Postby theelanman » Mon 27.09.2010, 15:30
:poke:
you might want to think about where you post your needs..... :-D
erm I found this in the snetterton special events section......
moved to bodywork questions
Re: front clam
Postby esext03 » Mon 27.09.2010, 16:12
thanks for this its the first time i have uesd the forum
et
esext03
Re: front clam
Postby lotusgirlmarie » Mon 27.09.2010, 18:10
It is a pain to remove the PS pump. On cars without a turbo upgrade you do have to remove the clam. On cars with the Garrett upgrade just remove the downpipe.
lotusgirlmarie
Goddess
Re: front clam
Postby texas2201 » Mon 27.09.2010, 21:15
my garage replaced the PAS pump without removing the clam
Re: front clam
Postby dapinky » Tue 28.09.2010, 05:59
I've done it without moving the clam - it's a while ago, and it came out of the bottom - can't remember anything else, so it may have been whilst the turbo was out!
Sorry to be so vague, but it's stupid o'clock in the morning and i've got a lot on my plate at the moment.
Re: front clam
Postby Enright » Tue 28.09.2010, 15:57
When I ported my wastegate I had to get the PAS pump out of the way to gain access to manifold bolts.
I didn't actually remove it, but I'm sure that it could have come out if I'd just undone the hoses.
Complete clamshell removal sounds excessive.
