Bob's Bits for Saab/Vectra Front Brake Upgrade
Re: Bob's Bits for Saab/Vectra Front Brake Upgrade
Postby lotos » Mon 11.10.2010, 15:59
FINAL DAY
Bob has asked me to handle collecting all the US funds, and send him one lump payment. Then, he'll create the kits and mail them out to everyone individually. So - please paypal me USD$60.00 and I'll mark your name paid on this list. (GBP Conversion plus paypal fee so Bob doesn't have to cover that) Let's keep it open for ONE MORE DAY to allow some time for anyone who wants in. So the list will close Tuesday, October 12.
My paypal address is lotusrandy (at) gmail (dot com)
1 ) lotos [paid]
2 ) nsr250 [paid]
3 ) racerstev [paid]
4 ) esprit888 [paid]
5 ) dunnlor [paid]
6 ) superbad [paid]
7 ) Brit-Car-Nut [paid]
8 )
9 )
lotos
Postby DangerMouse » Tue 12.10.2010, 22:31
1 ) lotos [paid]
2 ) nsr250 [paid]
5 ) dunnlor [paid]
6 ) superbad [paid]
8 ) DangerMouse [paid]
9 )
DangerMouse
Postby lotos » Wed 13.10.2010, 16:33
The list is now closed - if Bob wishes to continue this down the road for others, please PM him directly.
Here's the final list. Be sure to PM Bob your address so he can send it to you:
1 ) lotos [paid]
2 ) nsr250 [paid]
5 ) dunnlor [paid]
6 ) superbad [paid]
lotos
Postby bobbrown » Sun 31.10.2010, 15:07
1 ) lotos [paid] Sent 25/10/10
2 ) nsr250 [paid]
3 ) racerstev [paid] Sent 3/11/10
4 ) esprit888 [paid] Sent 25/10/10
5 ) dunnlor [paid] Sent 3/11/10
6 ) superbad [paid] Sent 25/10/10
7 ) Brit-Car-Nut [paid] Sent 25/10/10
Some have been sent (25th) rest will go out week commencing 1st Nov, please update when received.
Bob
Pacific Blue N/A
bobbrown
Postby nsr250 » Sun 31.10.2010, 20:03
PM'd my address to you.
Don
'91 Elan
'87 Milano
'91 318is
'02 Protege5
'02 DRZ400s
'91 VFR750
'98 VFR800
nsr250
Postby dunnlor » Tue 09.11.2010, 02:24
Received mine today.
Thank you, Tom
dunnlor
Postby esprit888 » Tue 09.11.2010, 03:54
2 ) nsr250 [paid]
4 ) esprit888 [paid] Sent 25/10/10-received 1/11/10-thanks Bob !
esprit888
Postby Brit-Car-Nut » Thu 11.11.2010, 02:56
2 ) nsr250 [paid]
7 ) Brit-Car-Nut [paid] Sent 25/10/10 Received 10/11/10 Thanks
Postby bobbrown » Thu 18.11.2010, 18:57
All now sent
1 ) lotos [paid] Sent 25/10/2010
2 ) nsr250 [paid] Sent 4/11/2010
3 ) racerstev [paid] Sent 3/11/2010
4 ) esprit888 [paid] Sent 25/10/2010-received 1/11/10-thanks Bob !
5 ) dunnlor [paid] Sent 3/11/2010 received 9/11/10
6 ) superbad [paid] Sent 25/10/2010
7 ) Brit-Car-Nut [paid] Sent 25/10/2010 Received 10/11/10 Thanks
8 ) DangerMouse [paid] Sent 18/11/2010
Pacific Blue N/A
bobbrown
Postby esprit888 » Tue 15.03.2011, 23:59
Still playing around with this, Bob, would this solve the parking brake problem ?? (with a little bit of modification for the latch spring)
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2405258953
[quote="bobbrown"][quote="esprit888"]Bob, This may sound like (and probably is) a dumb question but the Saab has discs on all four corners. With your rear hub kit could the rears also be replaced with the same Saab/Vectra rear brake upgrade ?
In a nut shell No as the rear handbrake on the MkI Saab/Vectra uses a combined disc/drum and is too deep to get in and the MkII does have a combined handbrake caliper but it will not fit. due to mounting restrictions.
esprit888
Postby bobbrown » Wed 16.03.2011, 00:36
esprit888 wrote:Still playing around with this, Bob, would this solve the parking brake problem ?? (with a little bit of modification for the latch spring)
Dual circuit brakes so two lines run to the rear!
Pacific Blue N/A
bobbrown
Postby Brit-Car-Nut » Wed 16.03.2011, 00:40
Isn't it a single circuit with one line being fluid source?
Postby bobbrown » Wed 16.03.2011, 01:02
Not sure about FED cars but ours have two lines running to the rear as it is a diagonally split sytem with one half of the master cylinder operating the front left and right rear and the other half the other two.
Pacific Blue N/A
bobbrown
Postby Brit-Car-Nut » Wed 16.03.2011, 01:06
Yes, the Fed system is one front and one rear per circuit.
The connections at the BMC are a little different with only 3 lines going to the BMC. There is a "Tee" fitting just below to get the 4th line connected.
I see the hydraulic HB lever as a single circuit. The front hose id for the fluid reservoir/source and the rear goes to the brakes. Thus, this wouldn't work for our cars?
Postby esprit888 » Wed 16.03.2011, 01:26
True enough but if it was tied in prior to its split (just after the pipe exits the MC) it may work, although it would lock one front and the opposite side rear :lol:
bobbrown wrote:Not sure about FED cars but ours have two lines running to the rear as it is a diagonally split sytem with one half of the master cylinder operating the front left and right rear and the other half the other two.
esprit888
Postby dapinky » Wed 16.03.2011, 20:22
A couple of points worth mentioning (or not, as you see fit!)......
......in the UK there can be problems with a handbrake which is hydraulic when it comes to the MOT test......
.....the 'official manual' (see here) is open to a variety of interpretations as to what is a 'solely hydraulic' system, and what is a 'hydraulically assisted mechanical'.
My way of looking at it is this.......
as long as the hydraulics operate a mechanical bit at the end (and it all works), then it is okay, after all, the only totally hydraulic brake system i can thing of is to drive your car into a river, as there is always a mechanical bit. :?
I have used such systems on rally cars for years and never had a problem, even with 'fly-off' systems, when it comes to MOT time - but i have heard of others who have great difficulty in finding a 'friendly' tester.......
.....that said, the idea above for having the handbrake work on one front and one rear wheel is legal - there is nowt to say it has to both be on the same axle - but it may cause a bit of a problem with the 'balance' test :lol: :lol:
Postby Brit-Car-Nut » Wed 16.03.2011, 20:35
Of course, you could get a bit crazy and swap the single system BMC for a tandom BMC and lock up all 4 wheels...
A lot of big trucks use a hydraulic parking brake system but they isolate the rears from the front.
I often wondered about the logic with the way Lotus split up the brake circuits as the front do the major work and having one front fail would make controlling the car difficult at best in the event of a hydraulic failure at speed.
If the front circuit failed, I admit it would be hard stopping, especially with the limit valves in the rear, but, at least, it would be balanced.
Postby esprit888 » Thu 17.03.2011, 00:45
I am VERY fortunate to live in a City that has no mandatory annual (MOT or otherwise) mechancial inspections (you should see some of the crap driving around :lol: ) and no air care/emissions testing so basically once its off the lot you can do what you like with it, within reason.
dapinky wrote:A couple of points worth mentioning (or not, as you see fit!)......
esprit888
Postby bobbrown » Thu 17.03.2011, 01:20
could be done with one of these
you'd probably be best plumbing it after the proportioning valves.
Would be tricky to do with the current handbrake lever as it is a pull action
Pacific Blue N/A
bobbrown
Postby esprit888 » Thu 17.03.2011, 01:38
Hmmm, looks way better Bob (do you ever sleep? :) ) Remember this was so i could use the Saab/Vectra rears as well as the fronts but its likely to cost more than a hi spec upgrade at this rate :D
bobbrown wrote:could be done with one of these
esprit888
