Specky wrote:The faults legend says "0", does that mean for the Whole time or just for that snap shot?
Specky wrote:I'm was after a more simplitic way of looking at it, a beginners guide as such...
Tonight I've had a chat with theelanman and this is what I think I understand:-
Get the Elan Scan up and running on your computer and get it hooked up to the car.
Basically start talking, start logging, start car, Aquire information for what ever duration you require, stop logging, stop talking.
Now save the run and name it as you wish.
Then it's on to diagnosis.
Looking at the left hand side of the screen,
You'll start with the Prom Id, basically what chip is running in the ECU.
Next is Faults, this should be zero, but if you get a fault, expand the drop down, you should see a list commencing with VSS, if any of these stays "ON", that's your fault.
(Is this same fault that puts on the CEL?)
Things that would be good to know are what perameters are acceptable,
Here's a few examples:-
1250 RPM is not acceptable at idle, but it is when you've just started the car it should drop in stages to about 950 RPM as the car warms up.
The themostat will open at 80-85 oC
The fans should kick in at 107- 110 oC
The "Elan Scan" coolant alarm will "Bing" at 100 oC
The fans should cool to about 100 - 103 oC
Basically all the parameters all the way down the left,
Things like the Spark advance would be good to know, Static and dynamic runs.
Finally, what are those Flags down the bottom?
Specky wrote:
I think we could all do with a bit of education.
Specky wrote:Just thought, there's gotta be an "AP" for that!!!
ivar wrote:It is not easy to understand the results from Elanscan. Like what is the correct data driving at 60mph in 3'rd, or 4'th.
Is there a manual somewhere, similar to the manual for "Freescan" (for Esprit's) ?
Lotus54 wrote:Is there an engine management manual for Federal cars?
I understand they are closed loop and what I saw in that manual was open loop.
I have a California car, anyone know the difference compared to 49 state?
