Nige wrote:Is that 90% based on physical movement, or the Throtle Position Sensor readout? I suggest the first thing to do would be to check foot flat onthe floor fully opens the throttle and adjust the throttle cable accordingly if it doesn't.
OZZY wrote:Attached hopefully is the file, can anyone read it and make sense of it because I can't, I really would appreciate some opinions on this as the results I'm looking at seem totally wrong, I floored it a couple of times to get some useful data whilst on the M1, then dropped off and parked up a mile or so from the motorway.
saska wrote:OZZY wrote:Attached hopefully is the file, can anyone read it and make sense of it because I can't, I really would appreciate some opinions on this as the results I'm looking at seem totally wrong, I floored it a couple of times to get some useful data whilst on the M1, then dropped off and parked up a mile or so from the motorway.
Looks like something went wrong with comms at about 300secs and it has thrown all the parameters way out, so I've chopped off the last bit and made a new file of the first part of the run.
This file looks pretty normal to me except that there are 3 knock events @ about 95secs but no spark retard was applied so they're probably not serious.
Max boost was 0.91Bar.
The secondary throttle never opened.
Since we only got data from a high speed run would be good if you did the following from cold:
1. Connect ES cable
2. Switch ignition on (but don't start)
3. Start logging
4. Press accelerator to floor and let it back up
5. Start engine -- let it warm up until the fans cut in.
6. Go for a run -- try to include some full throttle runs in second and third up to 5000+ RPM.
7. Stop and let it idle for 30secs
8. Stop logging and save the file
9. Post up the log file
OZZY wrote:The hose is straight at this point where it's had the inline connector fitted bypassing the bcv in the past, it might even have started to degrade. Are hoses still readily available?
OZZY wrote: How did you identify the corrupt data and filter it?
JonT wrote:OZZY wrote:The hose is straight at this point where it's had the inline connector fitted bypassing the bcv in the past, it might even have started to degrade. Are hoses still readily available?
I replaced most of my hoses with IIRC 5.6mm or 6mm (internal diameter) fuel hose. Halfords (and probably most motor factors) sell it in metre lengths then just cut it to whatever size you need.
saska wrote:OZZY wrote: How did you identify the corrupt data and filter it?
It was pretty obvious where things went screwy. This threw the x/y parameter scales way off.
Used the cursor on the graph to select 0-290secs (before the corruption) then Edit > Copy to New dataset
So now in the Select Table/Cursor Dataset dropdown you should have Dataset1 as well as the original file.
If you leave it on the original file and File > Close Dataset then it will show Dataset1 (with correct axis parameters). I then saved Dataset1 as Log2_1.ecu
OZZY wrote:JonT wrote:OZZY wrote:The hose is straight at this point where it's had the inline connector fitted bypassing the bcv in the past, it might even have started to degrade. Are hoses still readily available?
I bought some vaccum hose from Halfords in readiness but decided not to use tham as the internal diameter looked too small, I suppose fuel pipe ought to be good enough though.
OZZY wrote:When I start her up she is usually very fuelly, a strong smell of petrol which then goes away almost instantly, is this normal? She ticks over very lumpy when I first start her up as well as if she's only firing on 3 but I'm wondering whether the injectors are working properly as there is no backfiring. After a while she calms down and to drive away tonight she was fine.
Maybe someone can see whats happening from the data?
