Pinky II
Re: Pinky II
Postby surfboardfiller » Fri 28.05.2010, 18:20
Don't up the wattage or you will blind the driver behind when you brake. I think there are standard outputs of light the car will be permitted to produce. I'd drop the wattage if you are doubling up the bulbs.
Better you have more bulbs too, if one goes you still have lights. :D
The lights have reflectors in them so they should be fine without gash bumper stickers. :wink:
I'm not sure about double filament bulb fitments, there are only singles used on the Elan aren't there?
Looking good though matey!
surfboardfiller
Re: Pinky II
Postby Monty » Fri 28.05.2010, 19:36
The bulbs are standard wattage, it was blowing the fuse cause of going from 2 to 4 bulbs and require more amps to run all 4.
Even the fog on the elise light has a double element bulb but only one is used :roll:
Yeah thats another bonus with having more than one bulb, if one blows then the dip sh*ts can still see you :idea:
as i`ve got 4 bulbs for side lights and 4 for the brakes :-D
Re: Pinky II
Postby surfboardfiller » Fri 28.05.2010, 20:47
Monty wrote:The bulbs are standard wattage, it was blowing the fuse cause of going from 2 to 4 bulbs and require more amps to run all 4.
Yeh, I meant overall watts rather than per bulb. :wink:
surfboardfiller
Re: Pinky II
Postby Monty » Wed 08.09.2010, 18:15
It`s about time i updated this thread :roll:
22/7/2010
New Aluminium Raditator fitted
New cooling fans (Gordon specials)
KN oil Filter HP-1004
Q8 F1 10w/50 oil
Motul ATB 600 brake fluid
Coolant
Top Lugs removed
Hitting the Rad frame
Lower lugs and plastic lip removed
Re: Pinky II
Postby Monty » Wed 08.09.2010, 19:33
Another update,
Bob did me a Stiffer Spring setup but i had a nightmare with the Rear AVO`s, the adjustment knobs were Fecked and one of the large adjustment nuts for setting the height was seized :twisted: :evil: Had to cut of the nut and clean up the threads and send them off to AVO to have them refurbed, costs was just under £80 including postage and the large seat adjustment nut, have to say the service was great.
This time i`ve covered the Damper knobs and threads with copper slip and covered with gaffer tape :roll: should last many years :?
Suspension was completed on the 14/8/10
Spec:-
All springs are 2 1/2" Racing springs from http://www.dfaulknersprings.com
Front- 9" 450lb Main, 2" 150lb Helper
Rear- 9" 225lb Main, 2" 150lb Helper
Bob machined the spring carriers and as usual did a great job :wink:
Ride height has been set 25mm lower than stock
Front- 140mm
Rear- 129mm
CamBelt change on 15/8/10
Front Lower Carrier
Rear Lower Carrier
Center Spring Carrier
Upper Spring Carrier
Bellows from ROVER 213 & 216 1984 to 1989 - STEERING RACK BOOTS
Top Carrier
Front
Front
Rears
Rear
Re: Pinky II
Postby surfboardfiller » Mon 20.06.2011, 21:56
I got these from Lotus and thought of you.
surfboardfiller
Re: Pinky II
Postby Monty » Mon 20.06.2011, 22:23
Oh so there now doing the full christmas light effect :lol:
Re: Pinky II
Postby surfboardfiller » Mon 20.06.2011, 22:40
They could be for a Lotus Police car. :D
surfboardfiller
Re: Pinky II
Postby Monty » Tue 21.06.2011, 12:13
surfboardfiller wrote:They could be for a Lotus Police car. :D
Does the Evora have the same lights :?
Well Pinky has gone closed loops, had a Stainless O2 Boss welded in to the Stiffy and have a new switcher chip installed (thanks Alan). Just need to go for a run to test her to make sure the wiring is connected to the ECM
Denso 234-3014 O2 sensor
Lambda Sensor Boss Nut (M18x1.5) Stainless Steel
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0608303830
Re: Pinky II
Postby Monty » Wed 24.08.2011, 22:47
Nothing much to report, just that Pinky passed her MOT today with no prob`s :-D
With the O2 sensor fitted the emissions test result:-
CO 0.44 percent :-D (Max is 3.5)
HC 116 ppm (Max 1200)
Whats the Max results for an Elan with a Cat?
Re: Pinky II
Postby saska » Thu 25.08.2011, 19:25
Monty wrote:Whats the Max results for an Elan with a Cat?
Fast idle:
CO: 0.20%
HC: 200ppm
Natural idle:
CO: 0.30%
The S2 last MOT (stock exhaust with CAT, Everest chip, Jun 2011)
Fast idle:
CO: 0.12%
HC: 69ppm
Natural idle:
CO: 0.06%
Tony
adw (at) saska.co.uk
saska
Re: Pinky II
Postby Monty » Thu 25.08.2011, 22:21
Thanks Saska, looks like the Cats make quite a difference then :lol:
Glad i have an SE, but fitting the O2 sensor is well worth the effort to fit :wink:
Re: Pinky II
Postby chrisP » Fri 26.08.2011, 12:19
Monty, where did you get the O2 sensor from and how much did you pay (if thats not a rude question). I have a Bosch one in mine, but it keeps throwing a ECU error (and has done since I installed it) So looks like a change is in order.
chrisP
Re: Pinky II
Postby Monty » Sun 28.08.2011, 19:54
chrisP wrote:Monty, where did you get the O2 sensor from and how much did you pay (if thats not a rude question). I have a Bosch one in mine, but it keeps throwing a ECU error (and has done since I installed it) So looks like a change is in order.
Chris,
The O2 sensor came from the USA along with a 3 Bar MAP as it was for the LGM turbo upgrade kit i bought (still not fitted) only cost about £20 but had someone from the states to ship it over. Try doing a search with the part number
Think your getting an error code the same as i was because the wiring didn`t go all the way to the ECM and had to splice two wires to get it to work, which was done according to the writeup on the Wiki
Re: Pinky II
Postby chrisP » Tue 30.08.2011, 11:23
Thanks Monty, You learn something everyday, I had assumed that the wiring was all there when I installed the V5 Switcher and O" sensor!!! It looks like I have a little bit of investigating and wiring to do. Then hopefully some good fuel economy :clap:
chrisP
Re: Pinky II
Postby chrisP » Tue 13.09.2011, 13:04
All wired in and working now. No ECU eror lights and full boost again - I've missed that.
The plus point is that it appears to be sipping petrol now, rather than guzzling it, so happy days
chrisP
Re: Pinky II
Postby Monty » Tue 13.09.2011, 20:50
chrisP wrote:All wired in and working now. No ECU eror lights and full boost again - I've missed that.
Well done Chris :clap:
BTW, i now have a leak on the rear Hi-shite N/S caliper :evil:
Re: Pinky II
Postby surfboardfiller » Wed 14.09.2011, 09:10
Nige had a problem with his, something to do with the handbrake and pinching a seal. :?
I'll ask him tomorrow.
surfboardfiller
Re: Pinky II
Postby Dico » Wed 14.09.2011, 20:02
Lol. Where has Phil been hiding?
Re: Pinky II
Postby surfboardfiller » Wed 14.09.2011, 22:35
Dico wrote:Lol. Where has Phil been hiding?
In the Batcave :wink:
surfboardfiller
