by chetepongo22 » Wed 14.12.2011, 19:44
My alternator died.Is there another option that getting a new OEM part from lotus? Isuzu impulse? other GM part?
Thanks in advance for your help
chetepongo22
- Tinkerer
by saska » Wed 14.12.2011, 19:50
chetepongo22 wrote:My alternator died.Is there another option that getting a new OEM part from lotus? Isuzu impulse? other GM part?
Have a look at the fine
WIKI
Tony
adw (at) saska.co.uk
saska
by saska » Wed 14.12.2011, 19:51
WIKI
Tony
saska
by HJ2 » Wed 14.12.2011, 20:25
The WIKI so good, they named it twice!
by saska » Wed 14.12.2011, 21:03
HJ2 wrote:The WIKI so good, they named it twice!
<Grin>
The first submit got an LEC 'Whoops' error page so I submitted it again. Teach me to check properly after a Whoops page.
Tony
saska
by HJ2 » Wed 14.12.2011, 21:13
happens to me all the time
by muley » Sat 17.12.2011, 11:10
Warning - the Impulse one won't fit an Elan. TVOE
by HJ2 » Sat 17.12.2011, 11:38
Yup!
I had a reconditioned one, must have been from the impulse. The housing was 6 mm lager in diameter so didn't fit. Took me all weekend and my knuckes before i decided to measure the thing.
Why not get your current one out of the car, have it reconditioned at a local shop (there are many, many shops that will do just that) and build it in again?
by Elanlover » Sat 11.02.2012, 23:13
You might take the opportunity to look for an upgraded alternator that puts out more juice. I replaced mine a few years back and found one that was rated at 75amps (pretty sure that was it but its been a while) which is slightly better than the stock 65 amps.
by Scott J » Fri 30.03.2012, 21:06
my local mechanic got one from local motor factors through trial and error, tried a few, got one to fit, cost £100. That was last month. The one I bought 5 yrs ago cost me alot more!
Scott J
- The prodigal son
by inkitin » Fri 30.03.2012, 21:18
Scott J wrote:my local mechanic got one from local motor factors through trial and error, tried a few, got one to fit, cost £100.
That's interesting and a really good price, well done to your mechanic.
Is there any chance of a make and model number? This would be really helpful for others and for the Wiki.
91 SE Calypso Red
inkitin
by stevieg8571 » Sun 23.09.2012, 10:53
Scott,
Do you have information on the alternator numbers?
I may be in need of one, and any options would be helpful.
Cheers, Steve
stevieg8571
by alan e » Sun 23.09.2012, 16:42
Why not just get yours repaired there has been problems with the charge light not going out when buying one that fits but is not the right one which has been posted on here in the past, i got mine repaired by unit exchange on 08000528312 they will get it picked up and returned to you and you will know it will re-fit with no problem
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
by pearman00 » Sun 23.09.2012, 19:09
lotus number A100E60295 and the Denso number is 8943258452 hope that helps
pearman00
- Tinkerer
by stevieg8571 » Mon 24.09.2012, 10:34
Thanks for the numbers.
They should help in my search.
stevieg8571
by stevieg8571 » Wed 03.10.2012, 19:13
I had a
http://www.woodauto.com/zoomImg.aspx?Ref=ALT30391 fitted today.
The ignition light does extinguish, everything lines up & connects, and it's slightly uprated.
The only minor problems are
1, It's a little big bigger than the original Lotus one, but a bit of leverage sorted that, apparantly!
2, I appear to have bought their last one (although that doesn't mean they won't be getting re-stocked)
I posted this in the cross referance section.
Thanks once again for all your help & advice fellas, Steve
stevieg8571
