Sod it !!
Sod it !!
Postby Rambo » Tue 06.03.2012, 21:12
Went to take Rambo out for a Spring thrashing today :burnout: but as I turned out of the garage the steering felt heavy. No hissing snake on full lock either, just an awful grinding sound :? Garage floor covered in a pool of transmission/PAS fluid :shock:
Sod it !! A pipe appears to have ruptured somewhere near the PAS pump. Stuck in some more transmission fluid and turned lock to lock several times to bleed out any air bubbles but it looks fairly terminal. Anyone else had this problem recently and can give advice ?
Re: Sod it !!
Postby GeoffSmith » Tue 06.03.2012, 21:15
Yep!
Re: Sod it !!
Postby GeoffSmith » Tue 06.03.2012, 21:24
Guess you were expecting a bit more than that...
My incontinence thread and Monty's.
If dial up doesn't let you read all the posts before the weekend, check out the Wiki for a quick summary. :D
Re: Sod it !!
Postby Rambo » Tue 06.03.2012, 21:50
Thanks Geoff - dial up reading you loud and clear !!
I've used Pirtek before when my oil cooler pipes gave up the ghost. Good company, excellent service, not expensive etc. I think I will probably be renewing acquantance with them again tomorrow ;-)
Return to Chassis & Steering
