by Paul S4 » Fri 23.03.2012, 01:08
This is my first post on here...!
I am new to 'modern' Lotus cars, but very familiar with the 'classic' Elan !
As per title...I am considering getting a 1991 M100 SE; it will need a cam belt service. Does anyone know/recommend a specialist in the Co. Durham/Teeside/Newcastle area. Also what sort of cost will this be ? Is there anything else that should be done at the same time as the cambelt? Thanks in advance.
Paul S4
by Rice crispy » Tue 27.03.2012, 09:02
Can't help with the garage but everyone seems to do all the belts, and water pump as well. I had mine done a couple of years ago and got bits from SJ's and a mechanic friend who looks after his own exotics charged me about £250 iirc to do it all along with CAS seal, and full service (most of the parts I got).
Rice crispy
by abmunro » Tue 27.03.2012, 12:41
We have Formula One at Newcastle ( Expensive )
There is also Colin @ REVLINE whitley Bay ( Reasonable )
Tony
abmunro
by Rambo » Wed 28.03.2012, 07:49
Colin at REVLINE, Whitley Bay has an M100 himself so is well versed in the Elan
- Don't push me
by Fourdoorcat » Fri 30.03.2012, 00:29
Since the work required to replace the timing belt is rather significant, a couple of other things to consider replacing besides the accessory belts, water pump and CAS O-ring are:
Crankshaft seal
Camshaft seals
Cam cover gasket
Spark Plugs (possibly wires, depending on age)
"Bung" O-ring
Ken
"Never ascribe to malice that which can be perfectly explained by stupidity"
Fourdoorcat
by Paul S4 » Fri 30.03.2012, 01:08
Many thanks for all those replies. But what is a CAS seal?
Paul S4
by tigerdog » Fri 30.03.2012, 05:30
Paul S4 wrote:Many thanks for all those replies. But what is a CAS seal?
It's the o-ring that keeps oil from seeping out from behind the Cam Angle Sensor (round black thingie where the distributor should be at the right-front of the engine.)
Clicky for replacements of a better material than stock.
by Aoki Magic Pants » Tue 03.04.2012, 14:59
Just out of interest; where do you live Paul?
Aoki Magic Pants
Return to Engine
